ceramic cartridge 20.12.13 04:43 |
Registriert - Registered: 13 Jahre - Years Einträge - Posts: 121 |
Hello,
I've placed a new ceremic cardridge in my jukebox
The old one was also ceramic
But now i have a little over-modulation
How can i solve this?
Re: ceramic cartridge 20.12.13 14:23 |
Hello timroy
Which jukebox do you have? Which pickup was installed previously and which you have installed? Without this information it is difficult to help.
Best regards - charly49
Re: ceramic cartridge 21.12.13 04:43 |
Orginal was a philips ag 3010
The new one is a philips gp 230 with a higher output voltage
It's a wiegandt diplomat jukebox with a philips ve 1312 amp
Re: ceramic cartridge 21.12.13 09:42 |
Hello timroy
As far as I know, the AG3010 is a crystal - type, while the GP230 is a ceramic - type. Therefore, the AG3010 should have a higher output voltage (about 800-1000 mV) than the GP230 (about 200 mV). Unfortunately I could not find exact data for the two pickups. The amplifier should be able to handle both types. The maximum volume is expected to be slightly lower with the new pickup. If the old pickup played quieter, probably the crystal element is partially destroyed by humidity.
If you have the impression that the amplifier is overdriven, probably the amplifier is to repair. The input circuit may in this case be modified for a higher maximum volume if necessary.
Re: ceramic cartridge 21.12.13 10:46 |
Re: ceramic cartridge 21.12.13 13:45 |
SOLVED
I putted a resistor of 1,7 M ohm in serie and it works great again
Re: ceramic cartridge 21.12.13 14:13 |
Thank you charly49
