Nsm es prestige problem 21.04.24 07:46 |
Registriert - Registered: 5 Jahre - Years Einträge - Posts: 77 |
Hello all .
I have an NSM Prestige ES 160 with a 200watt central unit/amplifier.
Everything in the central has been renewed and everything works fine, but there is still a problem.
as follows,
turn on the jukebox.
make a selection and pick up the record and start playing.
now the sound of the first record is distorted for at least 30 seconds and then comes on and the sound is ( only the first record the second record sounds good )
I think it has to do with the bias being set just too low.
but nowhere is it described how this should be set.
Or are there any technicians among you who know another solution and have already had this problem?
All capacitors and various potentiometers and transistors have been replaced, just for your information.
Thanks in advance for reading, and I hope you have a solution, because I'm stuck right now.
kind regards, nico
as follows,
kind regards, nico
Re: Nsm es prestige problem 22.04.24 12:53 |
Re: Nsm es prestige problem 23.04.24 11:01 |
Ruhestrom steht doch im Schaltplan für den Verstärker .
Re: Nsm es prestige problem 24.04.24 17:51 |
Hallo Nico,
falls Du den Plan nicht hast: R150 so einstellen, dass bei der Brücke zum Kollektor von T108 15mA zu messen sind. Die Brücke ist im Plan eingezeichnet; ob sie real auch existiert, weiß ich leider nicht.
Alternativ könnte man auch den Spannungsabfall an R152 oder R153 messen, das sind dann aber nur 3,3mV!
PS: Die Verstärkerschaltung entspricht dem 76M, befindet sich nur auf anderen Platinen.
Re: Nsm es prestige problem 27.04.24 09:23 |
Thanks jens ,
I wil look in to that.
Only the first record after power on the jukebox this problem is present , second record sounds fine and so on .
The amp does not get hot ,and the power is good .
They told me that this is normal with a es 2 or es systeem, but its irritaties me al lot .
And seems to me its not normal this issue.
Regards, nico
Regards, nico
Re: Nsm es prestige problem 27.04.24 10:19 |
Ist die Musik denn Anfangs sehr leise und wird erst nach 30 Sekunden lauter und damit auch klar ? Dann könnte da noch ein Problem mit der Fade In Schaltung vorliegen .
Re: Nsm es prestige problem 27.04.24 13:29 |
Hi swen .
Indeed the sound is poor first 30 seconds and then it gets up to the preset volume on the controller and then its clear
Only the firts record after you turn the jukebox on .
So it can be the preamps circuits both u think ?
Regards nico
Regards nico
