NSM model 160 selection problems 19.09.18 14:24 |
Registriert - Registered: 5 Jahre - Years Einträge - Posts: 2 |
Hello ,
Hope somebody can help me.
I have a NSM model 160 with 2 problems , i will start with the first problem and that one is a major one.
When you push a selection it starts but takes no selection , it goes to the left and to the right where it parks.
The complete electronics has new capacitors , i did some measurements and most of them are Ok , even the 27 Volt line
in the LPI. When i manual hit the relais on the LPI he stops and plays.
Any advice ?
Thank you.
Any advice ?
Thank you.
Re: NSM model 160 selection problems 19.09.18 14:41 |
Re: NSM model 160 selection problems 20.09.18 12:22 |
Hast du die beiden Messpunkte 300V und 135V überprüft ? Sind beide Spannungen vorhanden ?
