Ima Ami j80h spring 08.07.14 09:08 |
Registriert - Registered: 13 Jahre - Years Einträge - Posts: 121 |
Hello jukebox fans
I'm Working on a jensen j80h
Is there a Tone arm cam keeper spring ??(see pictures)
If so where do i place it ?
Greetings
Tim
Greetings
Tim
Re: Ima Ami j80h spring 08.07.14 13:33 |
Hello Tim
You are right. There should be a spring like the one shown. You have to unscrew the lever which actuates the contacts. Then you place the spring so that the T-shaped part is above the curve of the tone arm cam.
Best regards - charly49
Re: Ima Ami j80h spring 09.07.14 04:11 |
