RO 1454 control box 20.05.13 18:44 |
Registriert - Registered: 11 Jahre - Years Einträge - Posts: 21 |
Hi there
can anyone tell me what resistor goes between the cancel relay and the 8 prong socket in the 1454 control box, it has something to do with the gripper motor.
thanks. alanm43.
thanks. alanm43.
Re: RO 1454 control box 20.05.13 19:51 |
as the 1454 is about the same as the 1448
sure you mean resistor instead of condenser ?
there are 3 .05 MDF 400V condensers in the control box
24AB2
as the coding on the condensers are in a way similar to resistors this might cause confusion
strangely enough in the manual there are 3 condensers
but the schematic of the 1448 shows 4
can't remember how many there were when I replaced them
1 mal bearbeitet. Zuletzt am 20.05.13 20:10.
24AB2
Re: RO 1454 control box 20.05.13 20:14 |
Hi ,
there is only one resistor inside the Control- Box and it's not in my scematic of the 1454 ?!?
I have one box in my storage and I measured the resistor with 5 Ohm ?
Regards B&K
Regards B&K
Re: RO 1454 control box 20.05.13 20:21 |
Re: RO 1454 control box 20.05.13 21:22 |
Re: RO 1454 control box 20.05.13 21:56 |
Re: RO 1454 control box 21.05.13 14:38 |
Hi alanm43,
I think , it will be not more than 5 Watt !
If you will be on a very safe side , take a 7 Watt resistor!
Regards Klaus
Regards Klaus
Re: RO 1454 control box 21.05.13 16:52 |
Hi B&K
iv gone for 6.8 ohm--7 watt resistor and it works fine
thanks alanm43
thanks alanm43
Re: RO 1454 control box 24.05.13 10:28 |
Registriert - Registered: 17 Jahre - Years Einträge - Posts: 172 |
Hi alanm43
Just a question:
What is the reason for the exchange of that resistor? With other words, what would happen in case of a faulty resistor?
regards
Eddie
Just a question:
regards
Eddie
Re: RO 1454 control box 24.05.13 11:09 |
Hi Eduard Furrer
I changed the resistor because the gripper motor was reversing very slow ,almost at a stop.
regards alanm43
regards alanm43
