Wurlitzer SL-600 Plays B- Side Mostly 19.01.10 10:37 |
Registriert - Registered: 14 Jahre - Years Einträge - Posts: 1 |
Hello from USA. Thank you for maintaining this website. I just recently purchased this Wurlitzer SL-600 circa 1986/87 . It is Made in Germany quality. It does have a problem. Most of the time it only plays the B side of the record even if the A side has been selected. Thank you in advance to whoever can give help or tips to solve this problem.
Re: Wurlitzer SL-600 Plays B- Side Mostly 19.01.10 19:34 |
Hi there!
Most probably your gripper motor runs too slowly. To find out, please select a record, press and hold down the cancel-button and check how long it takes for the mechanism to pick and return a record. A complete cycle - from the point where the gripper arm takes the record out of the magazine to the point when it is put back again - should not last longer than about 12 seconds.
If your machine needs a longer time, please check the gearbox for any hardened grease. If the gears appear to be all right, check and replace the motor.
C U
Catboy (Kai)
1 mal bearbeitet. Zuletzt am 19.01.10 19:36.
C U
Catboy (Kai)
