Tech. Rowe Ami cabinet speakers 01.05.07 14:02 |
Registriert - Registered: 19 Jahre - Years Einträge - Posts: 9 |
Hi,
i need to know the impedance for the cabinet speakers from a Rowe Ami
JBM or JAN.
I have a JBM with wrong speakers inside the cabinet and a blown output-
transformer.
The original speakers are L-5290, L-2539 and L-3745.
Greetings from Holland,
Iwein
JBM or JAN.
transformer.
Iwein
Re: Tech. Rowe Ami cabinet speakers 05.05.07 10:57 |
Hello Iwein,
unfortunately I have no exact information, which impedance the speakers have. But I think, they should have 8 ohms. In series to each side - speaker is a condenser (32 microfarad, 50 volts NON POLARIZED), in series to the small center speaker is condenser (4.25 microfarad, 25 volts NP) connected.
I think it is best, if you look for original speakers. Many parameters (not only impedance and size) must fit to get a good sound and it is very difficult to find the right replacement.
The blown output - transformer can't be caused by wrong or short-circuited speakers, it is caused by a too high current for a very long time in the power tubes 7868. This could be caused by a missing bias (- 15 volts on pin 2) or a defective tube.
I hope, this will help you
charly49
charly49
Re: Tech. Rowe Ami cabinet speakers 08.05.07 14:53 |
Hi,
i already have a 2 original side-speakers in good condition and i have a 8 ohm 12" from a rowe-ami EX-401 speaker. I also have a R-2620-A amp and we wil use this output transformer to rebuild the original amp. (This amp is in good condition.)
The amp in this JBM was a R-3390-A and R-3389-A pre-amp. I don't believe it's possible to swap the 2620 and 3390 without modifications.
Iwein
Iwein
