Rock-Ola Tempo-1 mono...Sound without Bass 01.11.23 12:11 |
Registriert - Registered: 6 Monate - Months Einträge - Posts: 6 |
Hello, i have a Tempo-1 120 select Mono.
the bass-sound from this jukebox is horrible.
If i put my telephone in the input then the sound out of the amplifer and speakers is very good, also the bass.
If i play it form the jukebox input, with the needle on the records..the bass addition is very poor....
What needle is het best needle for getting bass sounds? I thinks the amplifier is good because with another source playing it sounds perfect...
Or must i change something, other needle, other amplifier composition???
What can i do???
kind regards,
Peter
+31653769250
What can i do???
kind regards,
Peter
+31653769250
Re: Rock-Ola Tempo-1 mono...Sound without Bass 01.11.23 14:09 |
Registriert - Registered: 5 Jahre - Years Einträge - Posts: 1.140 |
Re: Rock-Ola Tempo-1 mono...Sound without Bass 01.11.23 14:18 |
Hello Jurgen:
i have the Pfanstil P132 installed as a needle and the orignial amplifier of the Rock-Ola 1468...MONO..
kind regards, Peter
kind regards, Peter
Re: Rock-Ola Tempo-1 mono...Sound without Bass 01.11.23 15:20 |
Hello Peter,
the original Mono amp is designed for the magnetic pickup GE-VR2. It has a low input impedance, when you connect a ceramic pickup like the P132, you are ending up with a totally wrong frequency response. Try to get the original pickup.
Rgds
Jürgen
Rgds
Jürgen
Re: Rock-Ola Tempo-1 mono...Sound without Bass 02.11.23 06:07 |
Hello Jurgen, thank you for the fine explanation of the frequency-issue and difference between the magnetick pickup and the ceramic.
I hope that de GE-VR2 still is available in the world..i hear many people say that they are not produced anymore or available anymore.
What is then the solution, because, really, the Tempo-1 is very very beautyfull, must i change the amplifier or ???
thanks very much Jurgen.
Kind regards, Peter
Kind regards, Peter
Re: Rock-Ola Tempo-1 mono...Sound without Bass 02.11.23 08:54 |
Hello Peter,
yes, they are not produced anymore since a long time, sometimes they pop up but at very high prices.
Maybe some other forum member can suggest a suitable replacement, I don`t want to do that without having tested it myself with the same amp and box.
Good luck !
Jürgen
Good luck !
Jürgen
Re: Rock-Ola Tempo-1 mono...Sound without Bass 02.11.23 08:55 |
hi Jurgen, anyway, i understand your point of view and is very professional..thanks for that :)
kind regards, Peter
kind regards, Peter
Re: Rock-Ola Tempo-1 mono...Sound without Bass 02.11.23 10:21 |
Du kannst im Grunde jedes Magent System nehmen sofern die Nadel das Auflagegewicht aushält . Allerdings erreichen die meisten Magnet Systeme auch nicht die Spitzenspannungswerte wie das VRII . Aber aus Erfahrung raus kann ich sagen das die Tempo I mit dem Shure 44 ganz gut läuft . Wichtig ist halt auch hier eine gute Nadel . Ich schreib das Extra nochmal weil es eine Menge billig Nachbauten gibt die Probleme mit dem Auflagegewicht haben .
Re: Rock-Ola Tempo-1 mono...Sound without Bass 02.11.23 11:40 |
Hello Swen, thanks for your reaction and sharing your good experience.
i was searching, conform your advise on the internet to Shure-44....i think you can guess it...there are so many different types of that Shure-44 that the next quiestion is....what do i need exact.
Swen do you have a description or a photo with the orderdetails of the Shure-44 which you use?
kind regards, Peter
if foto is too big for this medium then you can whatsapp me.
+31653769250
thanks again Swen and Jurgen...
kind regards, Peter
+31653769250
Re: Rock-Ola Tempo-1 mono...Sound without Bass 02.11.23 12:50 |
Ich selber hab die aus geschlachteten modernen Rock-Ola Boxen verwendet , Baureihe 442 bis 490 . Oder auch von Rowe AMI . Ich denke nicht das es von Seiten des Systems wirklich Unterschiede gibt , außer das der Halter bzw. die Anschraublöcher teilweise kürzer sind so das sich das System im Tonarm versenken lässt .
Die beiden sind versenkbar .
Re: Rock-Ola Tempo-1 mono...Sound without Bass 02.11.23 12:52 |
Vielen dank Swen...ich suche de Shure on the foto's and going to try them...if i have a result i will let you know....good, better or bad.
thanks again :)
thanks again :)
Re: Rock-Ola Tempo-1 mono...Sound without Bass 02.11.23 12:55 |
Die beiden sind nicht Versenkbar wodurch der Tonarm Extrem hoch steht . Es gibt auch noch eins mit der Aufschrift Rowe AMI . Wenn du meine Meinung Hören möchtest alles der selbe Kram bis auf die Befestigung / Systemhöhe .
Das E400 wurde in Deutschland von einem Automaten Ersatzteil Händler als Ersatz für das Shure 44 vertrieben . Ob das auch von Shure gebaut wurde oder nur so aussieht keine Ahnung .
