Wurlitzer 2000 problem 18.12.21 18:25 |
Registriert - Registered: 2 Jahre - Years Einträge - Posts: 3 |
Hello!
I have a problem with my Wurlitzer 2000 Centennial. When I was changing new records in, I made a mistake; I tried to play a record from an empty place. I filled the empty place, selected the disc again, but the carousel no longer rotates.
Can anyone help me with this?
Re: Wurlitzer 2000 problem 19.12.21 09:22 |
Hi Matthew,
If a selector pin pops up after selection, check if the loading switch is back in the „operating“ position. You can also check the saftey switch of the record guide. If this switch is not pushed in the magazine motor got switched off.
Last but not least check the fuses (not only visuable but with a meter).
Viele Grüße,
JukeboxChrisi
[www.juke-para.de]
1 mal bearbeitet. Zuletzt am 19.12.21 09:23.
Viele Grüße,
JukeboxChrisi
[www.juke-para.de]
Re: Wurlitzer 2000 problem 19.12.21 10:50 |
Hi Chrisi,
Many thanks of your help. All the fuses are visually ok, but have to check still with a meter.
Now I try to find what and where are loading switch and safety switch.
Kind regards,
Matthew
Kind regards,
Matthew
Re: Wurlitzer 2000 problem 19.12.21 10:54 |
Hi Matthew,
The saftey switch sits behind the „mechanism bow“ and is activated by a screw at the record guide.
The record loading switch is underneath the mechansim board in the front and is activated with the help of a lever. This is used to switch off the mechanism while changing records.
Viele Grüße,
JukeboxChrisi
[www.juke-para.de]
Viele Grüße,
JukeboxChrisi
[www.juke-para.de]
Re: Wurlitzer 2000 problem 21.12.21 09:17 |
I haven't been able to find fault. All fuses are OK. Loading switch is in operation position. The safety switch seems to work. Plug in connectors off and attached. Would there be any new ideas on how to proceed?
