OMT 1015 Vinyl 45 Serial # 29052929 11.06.20 04:10 |
Registriert - Registered: 3 Jahre - Years Einträge - Posts: 16 |
Thank you for this forum. My jukebox problem to begin with was that during the record being picked and attempting to play the record would set down on top of the tone arm. I was able to get record out and the 1st time this happened i could still play records. That was about 2 years ago. I was going to donate the OMT to a local museum and thought i should make sure it would play ok. Sure enough the same issue cropped up on 1st record being played. I was able to get the record out but the next attempt was same result. I gave the unit a few plays from the button inside near the coin slot. Nothing seemed to happen. I walked away for a couple minutes and when i returned a record was playing as it normally would but without any volume. Next i thought i would try to set it to the background continuous play. I thought i was following the correct steps and the l.e.d lights were responding very much as the instructions said would happen. Somewhere in this process the l.e.d went dark and no response from the selector buttons. I pulled the cover plate over the amp and found what i thought was one blown 3 amp fuse. I replaced it and it blew immediately. Later i found that 2 3amp fuses had blown. I replaced them and one of the fuses blew right away while another did not blow and a small light was glowing on the board. That fuse stayed good until the bubbles started to flow (could have been a coincidence of the timing) then it blew. That one seemed to be the amplifier as i heard the speakers pop. No sound at all prior to that. The selection readout l.e.d did not light up or flicker when plugging the box in after putting new fuses in. I have attached a picture of the fuse panel and the fuse that blows every time has red and white taped to it. The other fuse that stayed good longer was the one directly above it and in the picture no fuse is in that slot. Box still lights up and evrything seems ok. No selector functions available. Thanks in advance for help.
Re: OMT 1015 Vinyl 45 Serial # 29052929 11.06.20 04:30 |
Forgot to attach picture from prior post
Re: OMT 1015 Vinyl 45 Serial # 29052929 11.06.20 09:33 |
Registriert - Registered: 19 Jahre - Years Einträge - Posts: 4.230 |
Davon mal abgesehen das Englisch nicht gerade meine starke Seite ist . Endlich mal jemand der mit brauchbaren Infos rüber kommt bei der Suche nach Hilfe .
Der I84 Verstärker bei dieser frühen OMT ( Mai 1989 ) hat wahrscheinlich einen Schaden in der Gleichrichtung . Bekannt dafür sind die 1N4007 Dioden zwischen bzw. im Umfeld der beiden großen Elkos . Die Sterben gerne mal den Leistungstod , Prüf die auf Kurzschluss . Wenn du uns die Nummer der Sicherung nennst dann kann man noch genauer schauen welcher Kreis das ist . Denn auch der Gleichrichter oben links auf dem Kühlbelch geht schonmal kaputt .
Re: OMT 1015 Vinyl 45 Serial # 29052929 11.06.20 16:00 |
Thank you Swen. The fuse that always blows is marked as S13 the other fuse that does not immediately blow is S14. When i lift the record carrier arm the turn table does turn. Don't know if that helps you in assessing the problem. You are so kind to offer suggestions. If i had a local repair person i would gladly have them come to the house or take it to their shop.
Re: OMT 1015 Vinyl 45 Serial # 29052929 11.06.20 20:57 |
Si3 und Si4 sind für den Gleichrichter der oben links auf dem Kühlblech angeflanscht ist . Probier bitte folgendes . Zieh den Stecker von der Mechanik am Verstärker ab sowie sofern Belegt auch den für Zusatzgeräte und Probier ob die Sicherungen dann wieder Durchbrennen . Wenn ja liegt Wahrscheinlich ein defekt im Verstärker vor . Es kann sein das einer der Elkos C4/C5 einen Kurzschluss macht oder aber die Dioden D8/D9 . Eine andere Möglichkeit wäre das eine Endstufe gestorben ist da die beiden Sicherungen den Verstärker und auch Teile der Mechanik Absichern .
Wenn du ein Multimter besitzt ( ein günstiges für rund 10€ reicht ) kann ich dich auch Anleiten was du wo und wie mal selber Messen kannst um den Fehler noch weiter einzugrenzen .
Re: OMT 1015 Vinyl 45 Serial # 29052929 12.06.20 21:02 |
I removed all external input wire harnesses from amplifier. With both fuses in only the S14 blew immediately. The S13 stayed good. Before it was reversed. The S13 blew and S14 stayed for a short time.
Re: OMT 1015 Vinyl 45 Serial # 29052929 12.06.20 23:17 |
Dann würde ich sagen liegt dein Problem im Verstärker / Netzteil . Besitzt du ein Multimeter ?
Re: OMT 1015 Vinyl 45 Serial # 29052929 13.06.20 00:35 |
yes i have one
Re: OMT 1015 Vinyl 45 Serial # 29052929 13.06.20 08:36 |
Weil es einfacher und schneller geht kannst du erstmal die oben Beschriebenen Bauteile Prüfen . Also C4/C5 und D8/D9 . Stell dein Messgerät auf Durchgangs Prüfung und Messe jedes Bauteil . Also immer die schwarze Leitung an eine Seite die rote an die andere . Bei den Kondensatoren schwarz auf die Seite mit dem schwarzen Strich und rot an die Seite mit der Kerbe bzw. dem Teil wo der schwarze Gummi Verschluss sitzt . Es sollte dabei zu keiner Zeit ein Piep zu Hören sein sofern dein Messgerät im Durchgangstest sowas von sich gibt oder 0 Ohm auf dem Display erscheinen . Es kann sein das dein Messgerät bei den Kondensatoren erstmal ein Piep von sich gibt . Das sollte aber nach wenigen Sekunden aufhören wenn sich der Kondensator lädt . Es muss nicht sein das dieses Bauteil defekt ist es kann auch noch ein Fehler in den Endstufen Transistoren vorliegen dazu aber gegebenenfalls später mehr . Mess erstmal die vier Bauteile durch .
Wichtig ! Das Gerät muss dafür Spannungslos sein . Netzstecker ziehen !
Re: OMT 1015 Vinyl 45 Serial # 29052929 13.06.20 19:06 |
C4 and C5 tested good D8 gave a reading of .000 on the diode setting of my meter D9 fluctuated the settled at .553
Re: OMT 1015 Vinyl 45 Serial # 29052929 14.06.20 09:34 |
Dann würde ich fast sagen die Diode ist defekt . Wenn du Löten kannst dann am besten eine Seite der Diode auslöten und nochmal Messen . Wenn wieder 000 angezeigt wird ist diese defekt . Als Gegenprobe kannst du auch mal beide Leitungen vom Messgerät zusammen halten dann sollte da auch 000 stehen . Nur um Sicher zu gehen da ich dein Messgerät ja nicht kenne .
Man könnte auch einfach eine Seite mit einem Seitenschneider abtrennen dann braucht man erst einmal nicht Löten . Selbst wenn sie in Ordnung ist und du sie nicht wider flicken kannst , dieses Bauteil kostet 5 cent und fällt bei einer Reparatur sofern man sie nicht selber erledigen kann kaum ins Gewicht . Original ist bei mir eine 1N4004 verbaut du kannst aber auch eine 1N4005 , 1N4006 oder 1N4007 nehmen wobei die 1N4007 die stärkste und gängigste ist .
Wichtig du solltest schon ein bisschen Erfahrung beim Löten haben sonst zerstörst du die Leiterbahnen und dann wird eine Reparatur schwierig . Geh zur Not in einen Fernseh Reparatur Laden und erkläre dein Problem . Man wird dir für das wechseln einer Diode nicht das meiste abnehmen . Vor allem dürften die auch so eine Diode vorrätig haben da sparst du dann schon am Versand falls du die Bestellen musst .
Viel Glück
Viel Glück
Re: OMT 1015 Vinyl 45 Serial # 29052929 16.06.20 18:42 |
Took a few days for fishing. Now back to the OMT issue. Is there a secret to disconnecting the input ac cord at the power supply. That 3 wire white plastic connection is a bugger, I don't want to destroy anything in the process. I am taking the board to an electrical shop to get the diode replaced. I am not skilled enough at soldering to do it myself.
Re: OMT 1015 Vinyl 45 Serial # 29052929 16.06.20 19:11 |
Dummy me. I got the board out without taking the whole panel out. Off to the electrical shop. Will get back to you after the diode is replaced. Thanks for all your help.
Re: OMT 1015 Vinyl 45 Serial # 29052929 18.06.20 08:40 |
Hört sich doch gut an . Ich drück dir die Daumen das es nur so eine einfache Diode ist . Halt uns Bitte auf dem Laufenden .
Re: OMT 1015 Vinyl 45 Serial # 29052929 23.06.20 20:12 |
Thank you so much for your help. Unfortunately i miss diagnosed the diodes. A local repair shop replaced both the D8 and D9 I told them that the D8 was bad and to replace D9 also if any doubts. The diodes were so inexpensive that he replaced both and only charged me $2 total. He said the old ones were good but did not test them before removing them because of the bad information i gave him. The Elkos test good for continuity. So now i am back to square one again. Dummys do reside on this side of the Atlantic.
Re: OMT 1015 Vinyl 45 Serial # 29052929 25.06.20 13:15 |
Thank you Swen. Sorry for confusion. The jukebox is now in the same condition it was before testing the diodes. It will light up but no response from the selector buttons. It still blows the 3 amp fuses.
Re: OMT 1015 Vinyl 45 Serial # 29052929 26.06.20 07:25 |
O.K. dann machen wir mal weiter . Hätte ja auch mal auf Anhieb funktionieren können aber wie ich es schon befürchtet hatte ist wohl einer der Endstufen Transistoren defekt . War eine Faire 50/50 Chance .
Also unser nächster Patient ist der Transistor TR109 und TR209 ( linker Kanal und rechter Kanal ) . Bei mir sind das BD648 können bei dir aber auch andere Typen sein . Wurlitzer hat die Verstärker sehr lange gebaut und zwischendurch mal auf gängigere Typen umgestellt . Damit du die leichter Findest , es handelt sich um die größeren Transistoren die sich oben und unten auf dem Aluminium Kühlkörper befinden . Messe jedes Bein der drei Beine gegen die anderen mit deinem Multimeter auf Durchgangsprüfung bzw. Dioden Test also genauso wie bei den Dioden D8 / D9 . Hier sollte nirgendwo das Gerät 000 Anzeigen . Ich denke nicht das beide Seiten defekt sind von daher kannst du beide mit einander vergleichen . Die Seite bzw. der Kanal wo 000 im Display erscheint dürfte dann der Überltäter sein . Hier müssen wir dann Eventuell noch ein paar andere Messungen zur Sicherheit machen aber dazu später mehr . Wenn hier was defekt ist muss ohnehin ein wenig mehr Ersetzt werden aber wie schon erwähnt dazu mehr wenn wir den Kurzschluss gefunden haben .
Re: OMT 1015 Vinyl 45 Serial # 29052929 26.06.20 14:27 |
Re: OMT 1015 Vinyl 45 Serial # 29052929 26.06.20 15:49 |
Lower transistor tested good. Upper transister gave .000 reading on center leg.
Re: OMT 1015 Vinyl 45 Serial # 29052929 26.06.20 17:29 |
Das sollte dann also Tr209 sein . Prüf Bitte auch den Tr203 , das ist der rechts außen .
Re: OMT 1015 Vinyl 45 Serial # 29052929 26.06.20 18:39 |
Tr203 tested bad on middle leg
Re: OMT 1015 Vinyl 45 Serial # 29052929 26.06.20 20:44 |
Bitte auch noch Tr 202 ( BD140 ) testen . Hier ist von der Schaltung her und unter Berückichtigung das Tr 203 einen defekt hat damit zu Rechnen das du ein ähnliches Ergebniss bekommen wirst aber das Multimter sollte einen Widerstand von etwa 47 Ohm Anzeigen alles was darunter ist spricht dafür das auch der defekt ist . Bei Tr 210 ( BD139 ) ist es ähnlich da sollten es aber mindestens 15 Ohm sein . Wenn der Wert darunter liegt ist dieser auch defekt .
Re: OMT 1015 Vinyl 45 Serial # 29052929 27.06.20 22:43 |
not sure if the top one is Bd140. it gave me a reading of .829 and .831 the bottom one Bd139 was .591 and .593 both of them above the .47 ohns .15 ohms mentioned in your last post.
Re: OMT 1015 Vinyl 45 Serial # 29052929 28.06.20 14:14 |
Bild Tr202 Tr210 zeigt die beiden Transistoren um die es zuletzt ging .
Bild R220 10k zeigt den Potentiometer für den Ruhestrom .
Bild R220 R120 zeigt die Position beide Potentiometer für den Ruhestrom von Kanal links und Kanal rechts .
Jetzt wird es schwierig weil eigentlich müsste man jetzt die defekten Transistoren Tr202 und Tr209 auslöten . Noch einmal Messen ob diese wirklich defekt sind und dann sofern als wirklich defekt befunden diese ersetzen . Ebenso sollte man den Potentiometer R220 auf jeden Fall ersetzen . Das hat damit zu tun das Wurlitzer diese Poti mit rotem Lack gesichert hat . Dieser Lack kricht in den Poti und macht ein späteres Einstellen schwierig weil er zu Kontaktproblemen führt . Deshalb besser ersetzen . Da man ohnehin den Ruhestrom neu einstellen muss was kein Hexenwerk ist kann man das auch gleich für den anderen Kanal erledigen somit hat man den Verstärkern nach einer kleinen Ewigkeit an Betriebsstunden mal wieder neu abgeglichen . Daher das dritte Bild damit man sehen kann wo der Poti für den anderen Kanal sitzt . Das Problem sind jetzt Lötkünste . Ich würde sagen du hast jetzt das Maximum von dem was du selber an Arbeit daran leisten kannst erreicht .
Bau den Verstärker komplett aus bring ihn so zu dem Reparatur Shop zeig ihm das was du hier auf dem Forum an Hilfe schon bekommen hast und er wird das mit Sicherheit verstehen . Wichtig wäre aber das du ihm ein Schaltbild für den Verstärker I84 dabei legst . Dort steht auch drin wie und wo der Ruhestrom eingestellt wird . Er sollte als Fachmann damit klar kommen wenn nicht kennt er ja die Seite vom Forum und kann gerne noch Fragen stellen sofern welche Auftreten . So einen Musikbox Verstärker bekommt man ja auch nicht jeden Tag vor den Lötkolben . Man kann noch einige andere Bauteile im Umfeld dieser vermutlich defekten Transistoren Prüfen aber das wird jetzt ein wenig zu viel fürs Forum und ist in den meisten Fällen auch unnötig . Wie gesagt wenn er das Gelernt hat und sein Handwerk beherrscht wird er schon Wissen was zu tun ist vor allem wenn du ihm schon sagen kannst wo er Anfangen soll zu Suchen .
Re: OMT 1015 Vinyl 45 Serial # 29052929 28.06.20 15:45 |
Thank you Swen for your responses. You are very kind. GOD bless.
Re: OMT 1015 Vinyl 45 Serial # 29052929 22.07.20 22:46 |
A follow up. Thanks to Swen. My jukebox is now working as it should.
Re: OMT 1015 Vinyl 45 Serial # 29052929 23.07.20 10:51 |
Danke für die Rückmeldung und viel Spaß noch mit deiner Box .
Wenn ich mal Indiskret Fragen darf was hat er dir für die Reparatur abgenommen ?
Re: OMT 1015 Vinyl 45 Serial # 29052929 07.08.20 17:56 |
Ok. I did not diagnose the Elkos correctly. The only parts the repair man used was 2 Elko capacitors and 3 fuses on the amp board. I shot myself in the foot. I did however also get the SCC updated with 3 relays, 10 transistors and one capacitor. Thanks again for your advice. Main thing is i now have a working jukebox again. GOD bless.
