NSM e160 prestige problem help 17.01.19 23:02 |
Registriert - Registered: 5 Jahre - Years Einträge - Posts: 3 |
Hello, new to the forum my name is Carl I am from the UK. I acquired a NSM jukebox about a month ago, i sent carriage off for repair, new opto sensors and resistors all works good but there is a selection problem
The display counts as it should but doesnt stop at its resting position I can trigger the solenoid relay and it picks up and plays perfect
I presume the stop switch is supposed to reset the counter to 0 which it does not
I've been over both boards many times checked most component but it all seems ok
Any help would be much appreciated
Thanks
1 mal bearbeitet. Zuletzt am 18.01.19 10:12.
Thanks
Re: NSM e160 prestige problem help 17.01.19 23:19 |
Re: NSM e160 prestige problem help 19.01.19 15:04 |
Sorted now, the grey lead down the carriage had a lose pin which popped out the connector, pushed it back in and works faultless
Note to self... Check even the basic of things first
