Hi,
I have a problem with the left channel
When i enter p-53 i can change the right channel only the left channel stays at zero
Can somebody help?
Can somebody help?
Re: NSM ES V 15.10.18 18:56 |
P 53 and Push Button 3 for more.
Display End by 15
Go Back with Button 9.
This is not Working ?
0606 ist fine.
Display End by 15
0606 ist fine.
Re: NSM ES V 16.10.18 02:24 |
Registriert - Registered: 13 Jahre - Years Einträge - Posts: 121 |
No
That is not working
That is not working
Re: NSM ES V 01.11.18 09:40 |
Registriert - Registered: 5 Jahre - Years Einträge - Posts: 1 |
I have a very similar problem.
Cannot change left hand channel from 0 using P53
Jukebox (Juke2000 ES5.1) may be ok when powered on but very soon the fault will appear.
Also in normal operation my display should show 99 (credits) but instead when the fault is present it shows 00 05 and the light showing the hand pressing the buttons is lit.
It is as though the jukebox thinks the "-" ve volume control for the left hand channel (on the remote control) is being permanently pressed but it isnt.
I have proven that the fault is on the control board by swapping it between jukeboxes and the fault moves with it.
I suspect a faulty component on the controller board but am not sure what component that could be yet ?
Anyone got any ideas ?
Many thanks,
Dave
Many thanks,
Dave
