Jupiter H100 sound isn't good 17.02.17 10:53 |
Registriert - Registered: 7 Jahre - Years Einträge - Posts: 2 |
Hi everyone,
I got an old jupiter H100 from someone that only used it for display for the past years.
I know nothing about jukeboxes, but I wanted to make it work.
So I ordered new needles, and now it plays songs but the tunes sound 'off'.
As if the speed may not be correct but I can't make up if it goes too slow or too fast.
If I should guess the speed is too fast.
Is this a mechanic problem? Can I solve it myself? or is the problem the old speakers?
Thank you for your help!
Jara
Jara
Re: Jupiter H100 sound isn't good 17.02.17 13:03 |
A speaker can't change the speed of the record. If you are not sure if the speed is to slow or to fast, play the record on a normal record player and compare.
Re: Jupiter H100 sound isn't good 17.02.17 13:07 |
The speed is too fast, when I slow the wheel down with my finger it sounds ok. There's a black rubber band around the wheel, does that needs changing? Maybe it's worn off from being old so it spins too fast against the pin of the motor?
Re: Jupiter H100 sound isn't good 17.02.17 15:29 |
Hello JaraSponga,
Mostly the speed is slower resp. varies slightly (uneven) when the rubber ring does not have enough grip any longer.
To be sure which speed we're talking about: Mark the record with a dot a count how often it turns per minute.
Kind regards - Hildegard Stamann
