Continental turntable motor 24.01.17 17:23 |
Registriert - Registered: 7 Jahre - Years Einträge - Posts: 41 |
Hey. were exaktly should i oil the turntablemotor. Its hard to see from the servicebook. Hope you can help. Maybee a photo will be handy.
Cheers Giggs
Cheers Giggs
Re: Continental turntable motor 25.01.17 13:31 |
Hi Giggs,
Usually on the turntable motors of any Ami or Rowe Ami there are oil wicks on the top & bottom bearings of the motor, put one spot of oil on these oil wicks (or direct onto the bearing ifan oil wick can not be found. spear one dop of oil on the turntable/ plater shaft and one spot of oil on the idler wheel shaft or any linkage pivot points.
You do not want any trace of oil on the inner lip of the turntable or on the rubber of the idler wheel.
Regards
Alan
Alan Hood
ami-man
UK
Regards
Alan
Alan Hood
ami-man
UK
Re: Continental turntable motor 26.01.17 15:31 |
Thank you Alan!
