rockola 430 15.01.17 14:00 |
Registriert - Registered: 7 Jahre - Years Einträge - Posts: 137 |
hi
can anyone please give advice on my jukebox problem, the 430 is playing perfect but has just devoleped a fault ,when the tonearm reaches the end and the runoff on the record it does not operate the reverse relay and return ; i have relaced the control box thinking it could be the relay but no difference,
i have checked the tonearm switch and this operates as it should , the manual cancel button also does not operate , i have manually retuned the arm and tried again but no luck ,i checked the wiring as on the schematic and all seems right, the problem arose after the box had played a couiple of records ok
any help please
1 mal bearbeitet. Zuletzt am 15.01.17 14:21.
any help please
Re: rockola 430 23.01.17 17:42 |
Registriert - Registered: 16 Jahre - Years Einträge - Posts: 187 |
Take the control box off and supply the reverse relay externally with a 20 to 30 volt voltage. Does the relay then switch?
Re: rockola 430 26.01.17 12:51 |
hi
thanks for reply and advice ,i tested the relay and it works fine, i found the problem to be no1 micro switch which i changed and all back working ok ,again thanks for advice
bopper
bopper
