Hello |Wolfgang,
Welcome to the forum.
The Rowe Ami RI-3 uses the the Central Control Computer (CCC) 6-08870-01 (revision version can go to -06)
There can be up to 7 or 8 switches on the board dependant on the revision number.
S100 Most popular/least popular only active in service switch setting
S101 Memorec Reset (as above)
S102 Memorec Advance (as above)
S103 Playmaker Mode, off, 20min, 40 min, continous. All the setting other than off, play a B side record at random.
S104 Clear Selection Memory (clears any selections in the CCC memory)
S105 Manual Credit
S106 Normal/Test (on free play/credit when set to test)
S107 Standard/As Selected (normally set to standard to reduce wear on the mechanism, stardard is plys in sequence from 100 to 199 As selected would play any records selected in the sequence they were selected in, if you selected the same record 10 times it would play the same record 10 times where as normal would play the record once or if slow selection was made twice.
Regards
Alan
Alan Hood
ami-man
UK
