Rockola 414
geschrieben von - posted by seancalla
Rockola 414
12.04.14 11:07
Hi
I am looking for a photo of a rockola power supply from the early sixties with the Jones connections in particular the the wire colours and pinout at the low voltage connection point which is a 12 pin one. The reason i need it is that i am having difficulty locating a power supply with Jones connections for a rockola 414 so i want to see if a later power supply with molex connections will suit but just need to double check wire colous and lay out or could some one let me know the wire colours on the low voltage molex connection that connects to the power supply (12 pin connection), usually connects below the transformer, if someone can, could they list the wire colours starting at the top of the connection and moving left to right. The type of power supply is usually in the rockola series from 404 up to 434, or even post some photos
sancalla
Re: Rockola 414
23.04.14 13:24
Hi
Just making another request for the above information if someone could help
regards
Seancalla
