Wurlitzer 1015 color cylinder question 12.01.14 14:19 |
Registriert - Registered: 14 Jahre - Years Einträge - Posts: 33 |
Hello,
Does anybody know how many small ball bearings are supposed to be in the round "track" of the color cylinder support shaft.
Figure 27 (page 28) in the manual shows part number 44135 (Drive gear and pin assembly). It fits over the steel shaft and is supported by some loose ball bearings.
When I disassembled both the left and right units to clean and re-lube. I discovered one side has 13 bearings and the other has 9.
The one with 9 has a lot more slop and wear in the shaft, I will probably have to re-bush them.
How many bearings were in there originally ?
Thanks to all...
Tony
Thanks to all...
Tony
Re: Wurlitzer 1015 color cylinder question 12.01.14 22:25 |
Hello Tony
I observed different numbers of balls bearings in these units, too. I think some ball bearings were lost during the long time of use the W 1015 (the W 800 has the same "problem"....).
I always clean the units and fill up the units with as many ball bearings (I only use new ball bearings / 100 pieces are 3 € here in my hometown) that can fit in the unit.
This way the color cylinders move smouth and synchron for a long time.
Best wishes Axel
Best wishes Axel
Re: Wurlitzer 1015 color cylinder question 13.01.14 14:03 |
Hi Axel,
Thanks for the quick response ! You wouldn't happen to know the size of the bearings off hand would you?
I could take a few of them to the local supplier, to have them measure them, and see if they have them in stock.
Either way, I guess I have to come up with some more loose ball bearings.
Thanks again...
Tony
Thanks again...
Tony
