Platter Removal 09.11.13 05:27 |
Ich habe eine Rock-Ola 1448 Jukebox und wollen einfach nur den Rekord Platte zu entfernen. Es ist eine Schraube an der Spitze, aber es dreht sich um und wird nicht abschrauben. Gibt es einen speziellen Trick, um diese Schraube und die Platte zu entfernen? Vielen Dank.
Re: Platter Removal 10.11.13 14:44 |
you should be able to pull out the turntable ( no need to remove the bolt )
if not : probably a circlip at the bottom of the shaft behind the turntable motor
Re: Platter Removal 11.11.13 04:35 |
Thanks for the answer. The platter will not pull out, so will look under the motor and see what there is that possibly holding it in. Once out I should be able to hold the shaft from spinning and take out the top screw.
Re: Platter Removal 12.11.13 10:36 |
will be difficult to remove that circlip
only way to access it is through the small opening below the dress cap
1 mal bearbeitet. Zuletzt am 12.11.13 10:52.
Re: Platter Removal 12.11.13 16:54 |
With a flash light I was able to see a c-like little clip the is holding the shaft from being pulled out on the bottom of the motor. Getting to it looks to be very difficult. Not sure how to squeeze some pliers in there.
Re: Platter Removal 12.11.13 18:29 |
long small screwdriver ?
and extendable ( telescopic ) rod with a magnetic tip to make sure the circlip
doesn't end up where you can't reach or want it ?
