NSM Prestige (ES11) 20.08.13 17:27 |
Registriert - Registered: 15 Jahre - Years Einträge - Posts: 275 |
Hi
Looking for help with this jukebox. The machine was working perfectly up to a number of weeks ago and then one day a loud hum was evident, and the music is barely audible. The loudness of the hum increases when the volume on the control is raised. No hum is evident when the tone arm plug is removed or when the remote/volume control plug is removed. All fuses are ok and all led's are lighting as they should, no grounding issues with the machine or lighting circuit. I have a few spare control centre boards and amplifier pcb's so i have swapped and changed about with no luck, anyone any ideas
regards
Seancalla
regards
Seancalla
Re: NSM Prestige (ES11) 20.08.13 19:03 |
Registriert - Registered: 16 Jahre - Years Einträge - Posts: 1.092 |
Hello Seancalla!
The Type is not ES 11 (eleven) it is ES II.
I think your Problem is in the Cable from the Pickup to the Amplyfier.
Make a Control of the Resistance from the Pickup on the Plug which is
connected in the Amplyfier. I belive the Shield of this Cable is interrupted.
mfg Willi!
mfg Willi!
Re: NSM Prestige (ES11) 20.08.13 23:41 |
Hi
Is it possible to bypass the carriage pcb and wire directly from tone arm to amp
regards
seancalla
regards
seancalla
Re: NSM Prestige (ES11) 21.08.13 00:31 |
Hi
Just an update, i checked continuity for the left and right signals and shield from the cartridge to the carriage pcb and input plug for the amp and i can't find any breaks or any continuity errors,
regards
Seancalla
regards
Seancalla
Re: NSM Prestige (ES11) 22.08.13 17:23 |
Registriert - Registered: 12 Jahre - Years Einträge - Posts: 1.003 |
seancalla schrieb:
> Hi
> regards
> seancalla
Hello,
the answer is YES.
Regards PitinWHV
> Hi
> regards
> seancalla
Hello,
the answer is YES.
Regards PitinWHV
Re: NSM Prestige (ES11) 22.08.13 18:54 |
Thanks for the reply, i presume it wont affect the mute function, or why do NSM wire the tone arm cables to the carriage pcb in the first place and then to the amp
regards
seancalla
2 mal bearbeitet. Zuletzt am 22.08.13 22:27.
regards
seancalla
