Direct to Vinyl Comeback
geschrieben von - posted by tubesglow
25.03.13 20:28
Hello All,
I just saw this recent post on slashdot that was just posted. Interesting article. The video is a good watch, and the gentleman involved are from Germany. Does anyone having any knowledge of these discs working on a jukebox? Might be worth checking into.
Tony
[entertainment.slashdot.org]
Re: Direct to Vinyl Comeback
26.03.13 14:37
Yes, these records are just like a normal pressed record. There's only one little difference, they are completely flat. On pressed 45s, the record is a little bit thicker in the label area, and thinner at the center hole.
That was done to protect the recording surface when they were stacked on changers.
So, some record changers may have problems with these records, but most jukeboxes grab the records on the outer edge.
There are some small companies offering a recording service, using these recorders, prices are between 20€ and 25€ for a double sided 45 with large center hole.
The records work very well in a jukebox and sound just like a pressed record.
The recorder is available for more then ten years now.
