rockola 1455d 27.12.12 20:01 |
Registriert - Registered: 11 Jahre - Years Einträge - Posts: 21 |
hi, i am rebuilding a rockola 1455d. the problem i have is that the title drum is revolving in reverse. the wiring checks out ok
according to the schematic diagram.
any ideas
any ideas
Re: rockola 1455d 28.12.12 06:32 |
Hello alanm43
It is nearly impossible that the motor rotates in the wrong direction. The only possibility is that it is assembled incorrectly. For a correct selection the direction of rotation of the motor and the drum is not important. It would have to be properly selected, even if the drum rotates in the wrong direction.
Best regards - charly49
Re: rockola 1455d 28.12.12 09:39 |
hi charly49
you are correct in your asumption,it selects correctly even though it revolves the wrong direction.maybe i will change the
AC motor. best regards-alanm43
Re: rockola 1455d 29.12.12 18:04 |
thanks charly49 for your imfo, i have solved the problem. i split the gear housing which holds the ACmotor, turned the motor around , reassembled the housing ,put it in the juke and every thing works fine,
alanm43
alanm43
