AMI ROWE RI-1G Wiring issues.... 06.11.12 21:57 |
Registriert - Registered: 11 Jahre - Years Einträge - Posts: 1 |
Hello
I recently bought a AMI ROWE RI-1G, and when I finally got it open I saw one cable disconnected and one cable stripped down.
Can anyone give me any pointers, where they should go?
Mike
Sweden
Mike
Sweden
Re: AMI ROWE RI-1G Wiring issues.... 07.11.12 23:34 |
Hello Mike
I think the connector is provided for additional equipment, probably for a wallbox - system.
The cable could be the pickup cable. Unfortunately is not visible in the picture, where it leads. It would have at the other end, two RCA plugs that are plugged into the preamp.If it is so, then is missing the plug, which fits into the seven pin socket next to the tonearm.
Greetings from Austria - charly49
Re: AMI ROWE RI-1G Wiring issues.... 08.11.12 16:14 |
Hello Mike,
If you could show us a larger picture of the inside of the jukebox so we can see the location of the cables and plug/loom that you talk about we can give you a better answer to what you need to do.
The loose cable could be from the phono connection but then again it could form part of the volume control wiring which ought to be the same four wires and a sceened cable.
As Charly49 says the plug could be for an item not used on the jukebox.
Regards
Alan
Alan Hood
ami-man
UK
Regards
Alan
Alan Hood
ami-man
UK
