Mit neue microschalter problem grosser.... 22.03.10 20:47 |
Registriert - Registered: 15 Jahre - Years Einträge - Posts: 19 |
Hello again, i mounted 4 new microswitches at the selector, as you gentlemen thought that was my selector problem.
Now 101-120 is not taken at all, instead it plays 21-40 ?????
The rest seems to be working allright.
I have read in the manual about these switches do arange which numbers are taken.
Is there a possibillity that it has to be adjusted in some way? i screwed it back together thats all.
Or did i by mistake switched a wire which is now in the wrong place?
Somebody please?
Tnx in advance
1 mal bearbeitet. Zuletzt am 22.03.10 20:47.
Somebody please?
Tnx in advance
Re: Mit neue microschalter problem grosser.... 23.03.10 10:09 |
Hello uncels
The new switches must be adjusted after installing. Each switch must click audibly, as soon as the lever falls into the recess of the cam. Clicking must arise, if the lever has moved the half way down (and up). I think, there are small srews on the levers for each switch to adjust this.
If the switches are well adjusted and the error exists further, you have probably some wires exchanged.
Greetings - charly49
Re: Mit neue microschalter problem grosser.... 23.03.10 19:06 |
Tnx charly, i bought a special inbus key & thaty problem is solved now.
What remains are a couple of selections that refuse to work, i hear a dull noise and after about 10 times i hear the click, but no response.
Could this be the selector itself (all looks clean to me)
greetz uncels
greetz uncels
Re: Mit neue microschalter problem grosser.... 24.03.10 06:18 |
Hi uncels !
It seems to me , that this is a typical selector problem.
The problem is inside the selector and if you want a functional
jukebox for the next years , that`s the work for you to do !
Look to the image : my selector inside !
Regards Klaus
