Rockola 470 blown by incorrect Voltage 06.02.19 00:07 |
Registriert - Registered: 5 Jahre - Years Einträge - Posts: 6 |
Please help
My friend plugged my 110V Rockola 470 into a 220V wallsocket without the transformer. What kind of damage can I expect and how can I fix it? Is there something as simple as a fuse blown or is it a major damage?
Tommy Elvis
Tommy Elvis
Re: Rockola 470 blown by incorrect Voltage 06.02.19 15:02 |
Registriert - Registered: 7 Jahre - Years Einträge - Posts: 112 |
Hi Tommy,
normally, if you are lucky, a simple fuse is blown in the primary circuit of the power transformer. Should there be no fuse or a wrong one, the power transformer itsself can be damaged.
Regards, Dieter
Regards, Dieter
Re: Rockola 470 blown by incorrect Voltage 06.02.19 19:19 |
Thank you Dieter for your quick response
Would it be the entire power supply unit that I need to replace:
ROCK-OLA 469 & 470 jukebox part: Tested / Working POWER SUPPLY 48445-1-A
Or is there a separate transformer on these machines?
Re: Rockola 470 blown by incorrect Voltage 06.02.19 20:47 |
I don t really know, I need the schematics.
Maybe someone else has the answer.
Dieter
Dieter
Re: Rockola 470 blown by incorrect Voltage 07.02.19 07:00 |
Hello Tommy,
before replacing the power supply unit, you should check also all secondary fuses in your box.
As far as I can tell from the pictures, there are 3 "circuit breakers" on the left side (simply push in) and 2 or 3 glass fuses inside the power supply unit.
In the user manual or schematics, you should find the location of all fuses in your box and their correct vlaues.
Good luck !
Jürgen
Good luck !
Jürgen
Re: Rockola 470 blown by incorrect Voltage 07.02.19 18:37 |
Thank you Jurgen, that's very helpful :)
Re: Rockola 470 blown by incorrect Voltage 07.02.19 19:37 |
There's only one reason to change the complete power supply, a blown transformer, simply because it's cheaper.
All other problems, like blown fuses, shorted rectifiers, exploded capacitors, can be repaired.
To prevent this problem, it's a good idea to mount the 230V to 120V transformer permanently inside the jukebox.
Re: Rockola 470 blown by incorrect Voltage 08.02.19 11:21 |
Registriert - Registered: 19 Jahre - Years Einträge - Posts: 4.234 |
Schau mal in deine Private message
