Wurlitzer Atlanta II - what to do
geschrieben von - posted by jonwarby
27.09.26 18:05
Hi everyone, I picked up an Atlanta II when I sold a rowe Anni jukebox. It hadn't worked for years and they wanted it out of the way. I've been having a look at it and I'm at the point of either selling it on or parting it out at I don't see another cleaner option but thought I would post here first incase anyone had any ideas. I've struggled to find parts and information for it. I have a decent manual that although isn't specifically for this jukebox it's fairly close but I've not found any reference for the amp which I believe is an s74 amp. The amp is blowing fuses as one of the windings is shorted to the chassis. Getting it rewound seems to be about £220 which is more than I want to pay as there are probably further faults. The volume control has also been removed.
Has anyone got a reference for the s74 so I can work out the voltages that the transformer is meant to be supplying? Has anyone had any luck with using something modern to supply the different voltages or does it just get to difficult trying to get on top of noise?
I would much rather try to get it working if possible but I've been surprised at the lack of information on these
If anyone does have any ideas that would be appreciated
Re: Wurlitzer Atlanta II - what to do
27.09.26 23:19
Informationen gibt es wie Sand am Meer aber nicht unbedingt auf Englisch . grinning smiley
Der Verstärker / Netzteil ist eigentlich ziemlich simpel aufgebaut . Welche Sicherung spricht immer an ? Bei der Netzsicherung kommt der Entstörfilter in die nähere Auswahl weil die eigentlich immer defekt sind . Beim Verstärker muss man unterscheiden zwischen Spannung für den Verstärker und Spannung für die Mechanik . Die Spannung für die Mechanik wird über zwei große Dioden ( roter Deckel , schwarzer Kühlkörper mit Isolierschlauch drüber ) gemacht . Die gehen schon mal kaputt vor allem wenn es Probleme mit dem Getriebemotor gibt und irgend so ein Spezialist die Sicheurngen 3,15AT überbrückt hat . Der Verstärker wird über einen Gleichrichter Betrieben der eigentlich völlig unproblematisch ist . Auch die Endstufe ist kein wirklich Ernst zu nehmender Gegner . Die besteht aus 2N3055 und BC 140 / 141 als Treiber . Also nichts Exotisches . Problem ist der Lautstärkeregler . Wenn der von der Platine ausgelötet wurde dann muss da eben ein Fernlautstärkeregler dran gebaut werden . Ist unter dem Strich einfacher als den Originalen zu besorgen der nicht mehr gebaut wird . Kommt außerdem von den Kosten nahezu aufs gleiche raus .
Man muss zwar einiges einfach Überholen aber letztlich sind das recht dankbare Boxen und die Atlanta 2 ist dazu auch noch Form und Farbtechnisch sehr schön wenn man dieses Bunte Design mag . Nur das ist halt eine Oma die braucht jetzt erstmal ganz viel Pflege weil die halt über 50 Jahre alt ist und da ewig keiner was dran gepflegt hat . Ersatzteile gibt es bei jukeboxparts.co.uk . in Mengen .
28.09.26 00:48
Thank you for your advice and information about the amplifier
The fuse in the top of the picture is blowing. One side of the fise is connected to one of the outputs on the transformer and has a direct short to the amplifier chassis which is why I think the transformer either needs to be rewound or I need to remove the transformer and use separate power so that's it's safe.
28.09.26 09:04
Klassischer Messfehler grinning smiley , die Wicklung liegt mit der Mittelanzapfung auf Masse / Gehäuse . Somit hast du rein vom Messen her einen Kurzschluss zum Gehäuse von den Gewebe Ummantelten Leitungen weil der Widerstand der Wicklung so gering ist .
Entweder ist wie schon oben erwähnt eine der beiden Dioden durch oder irgendwas im Gerät zieht zuviel Strom so das die Sicherung durch brennt . Meistens ist es der Getriebmotor MM der zuviel Strom aufnimmt . Der Abrieb der Motorkohlen und das altes Fett vom Getriebe sind da die beiden Haupt Verursacher . Wenn man den Motor als Sicherung Zerstörer Identifiziert hat reicht es meistens diesen Auszubauen und den Kohlestaub darin zu entfernen . Hinweis , nicht die drei Getriebe Schrauben raus drehen , nur Lösen ( Größe 7 ) und von den beiden Anschlusskabeln ein Bild machen sonst läuft der Motor am Ende falsch herum und zerstört Mikroschalter am Getriebe oder Teile des Getriebes .
28.09.26 10:13
Thank you Swen, that's amazing if I am just reading the transformer incorrectly. That gives me hope, i just stopped when I found that as I compared it to the other windings and other transformers that I have and they didn't seem to have the same short.
The fuse is blowing when not connected to the jukebox so I'll start testing the components in the amp starting with the ones you have suggested and report back.
Thank you.
2 mal bearbeitet. Zuletzt am 29.09.26 20:13.
02.10.26 00:18
I've made some progress. Thank you again for taking the time to reply as I was heading down a rabbit hole after measuring the transformer incorrectly. One of the diodes had failed, after replacing that and not putting any strain though the amp it's not blowing the fuse.
The gripper arm picked up a record and then froze half way. I'll follow your advice and try to remove and clean the motor as a starter.
02.10.26 02:40
Schön zu Hören das es vorwärts geht .
Je mehr ich zu sehen bekomme desto mehr keimt die Frage in mir auf was zur Hölle haben die mit dem Teil angestellt ?
Ich hoffe du hast die Soffitten und das Relais vom Verstärker entfernt und nicht der Vorbesitzer der auch den Lautstärke Poti raus geklaut hat .
Kleiner Tipp , der Plattenteller Tisch ist noch der alte mit Idler Rad der braucht zwei dicke Riemen damit der ordentlich läuft . Mit nur einem Riemen neigen diese Antriebe zum Leiern . Die neuern mit dem oben Liegenden Synchronmotor braucht nur einen dünnen Riemen .
Du solltest dir , wenn du schon Ersatzteile bestellst auch gleich die Nockenscheibe auf der Rückseite des Getriebes anschauen . Gern ist der Weichmacher raus und die Scheibe bricht am Anschraub Punkt ( zwei Madenschrauben ) und dreht dann auf der Achse durch . Das kann auch der Grund sein warum der MM Motor stehen geblieben ist .
Sofern du eine neue Nadel für das Original Wurlitzer System kaufen möchtest , gut gemeinter Rat , Lass es . Kauf lieber gleich ein neues System . Beim Nadel wechsel bricht gern der Haltesteg der Nadel aus dem System , diese hält dann nicht mehr .
03.10.26 18:29
Thank you for your comments again. I'm slowly learning more about this machine.
The bulbs weren't there, I've got some more now but not fitted them whilst the fuse was blowing. The relay on the amp was also missing but I've found one in the bottom of the machine which I think is the right one. Also not fitted yet.
Thank you for the note on the additional belt. Hopefully I can get it to the stage where I am worried about the sound wobbling.
I spent a bit more time with it today. The cam was slipping. I took it out and did a temporary repair whilst I try to track down a replacement. When I put it and turned the jukebox on, the gripper arm returned to the carousel. I was unable to make a choice, when I pressed the buttons they stayed in, there was a noise from the carrasel but no movement. I think I then moved the cam a bit and the arm moved to the record down position and the turntable started spinning. I placed a record on the turntable but there was no sound. At this point I was unable to cancel it either by moving the tone arm or by pressing either cancel switch.
I guessed this may be due to the cam not being aligned properly. I loosened the cam and got it to return but struggled to figure out what the proper alignment should be. I then started to turn the cam whilst it was loose to see if I could work out what the alignment should be and at that point it blew the diode and fuse again.
I think the next step is to work out how to align the cam and get a replacement cam. Fit it on the correct alignment and then see how it behaves from there
04.10.26 11:57
Ein bisschen Basis Wissen .
Die Soffitten auf dem Verstärker haben 6V 18W später Verstärker haben 24V 18W . Die Liegen von der Schaltung her in der Lautsprecher Leitung . Wird dem Verstärker zu viel Leistung abverlangt durch eine zu niedrige Impendanz der angeschlossenen Lautsprecher oder einem Kurzschluss in der Lautsprecher Leitung fangen diese Soffitten an zu Leuchten und sollen so den Verstärker schützen . Fehlen diese kann aus dem Verstärker nichts raus kommen . Das ist so als wenn die Lautsprecher nicht eingesteckt wären .
Das Relais schaltet die Spannung für den Verstärker ein . Das passiert jedesmal wenn die Kerbe an den Nockenscheibe die obere Position erreicht . Daher kommt letztlich auch das Dt. Wurlitzer typische "Fump" Geräusch wenn der Verstärker zu schaltet . Insgesammt hat dieses Modell drei Relais . Eins für den Verstärker ( das ist bautechnisch das größere der V23154 Serie ) . Eins für die A-B Seiten Bestimmung auf dem Chassis vor dem Greifarm und ein weiters auf der kleinen Platine oben an der Tastatur . Die beiden letzen Relais gehören zwar auch zur V23154 Serie sind aber deutlich kleiner . Ich hab hier schon mehrmals Ausfürlich darüber geschrieben was die ganzen Zahlen und Nummern auf den Relais zu Bedeuten haben um Ersatz zu beschaffen . Leider haben es diese Informationen noch nicht ins Archiv geschafft .
Daher hier mal den Link zu einem Beitrag wo es auch um die V232154 geht .
[forum.jukebox-world.de]
Zur Info , du brauchst um oben an die Tastatur zu kommen den Gehäuse Schlüssel WUA 1 . Ich meine mich zu erinnern das die untere Rückklappe auch ein Schloss hat , da passt der Gehäuseschlüssel ebenso . Den WUA 1 kannst du bei sämtlichen Jukebox Parts Dealern nach kaufen .
Zum Thema Nockenwellen Scheibe , Bitte mal diesen Beitrag durchlesen .
Die Scheibe auf dem Bild ist nicht in Ruhestellung Fotografiert . Damit die Steuerzeiten passen muss die Greifklaue unten am Greifarm völlig geöffnet sein wenn der Greifarm über dem Platten Magazin steht . Dann ist der untere Mikroschalter K6 betätigt . Obwohl das ganze sehr Grob aussieht kann es sein das die Scheibe leicht vor oder nach Justiert werden muss . Das kann man aber letztlich erst sehen wenn die Maschine komplett läuft weil erst dann geprüft werden kann ob man die Richtige Grundstellung getroffen hat . Hat man das nicht gibt es Probleme mit dem Tonarm . Dieser hebt dann nicht ab , schaltet am Ende nicht oder wird nicht frei gegeben . Such dir was aus es gibt da viele Fehlerbilder wenn diese Verdammte Nocke nicht Richtig steht .
Nochmal zum Verstärker , geh davon aus das du den Überholen musst und eine Neu Einstellung von Symetrie und Ruhestrom Nötig ist . Aber das ist ein Thema für sich das sollten wir dann in einem neuen Beitrag abarbeiten . Auch müssen dafür ein paar Grundkenntnisse vorhanden sein was Meßtechnik angeht und der Umgang mit Lötzinn , Lötkolben und elektronischen Bauteilen .
08.10.26 15:20
Thank you for all of the details information again.
I've 3D printed a new CAM and that seems to be working well.
The record pickup arm goes through the cycle a lot better now.
I'm still blowing fuses. I now think it's linked to the record carousel. Next step is that I'm going to unplug elements of this from everywhere that I can to see if that stops it and then plug bits back in to see if I can prove this and then isolate which part of it may be at fault.
I am off to Germany for a week so will probably try this when I get back.
I do have the right voltage / wattage bulbs and your information on the relay was really useful. I haven't tried any of them yet until I can get the carousel to move and the fuse to stop blowing.
08.10.26 22:40
Also immer noch Sicherungsprobleme . Wann brennt die Sicherung denn durch ? Vor allem sind die Richtigen Sicherungen verbaut ? Es gab da Änderungen ich muss aber erst schauen welche Sicherungen und ab welchen Verstärker . Die späteren haben 3,15A träge bis auf die Netz Sicherung die hat 2A träge . Bei früheren gab es auch mal die Kombination aus 2A träge und 3,15A träge und bei der Verwendung von einem Stepper für die Fernwahl mussten zwei gegen 6,3A getauscht werden . Sofern aber kein Stepper verbaut ist bleibt es bei maximal 3,15A träge .
Wichtig ist hier das du den Richtigen Kreis verfolgst . Es gibt einen AC Kreis und einen DC Kreis . Bleibt der Getriebe Motor ( MM ) stehen wenn die Sicherung auslöst dann liegt das Problem im DC Kreis . Auch das Kreditwerk arbeitet dann nicht mehr . Ich hatte auch schon Böse Fehler im Kreditwerk . Dort sind Kondensatoren verbaut die schon mal durch schlagen und so einen Kurzschluss verursachen . Es gibt aber auch die Möglichkeit das ein Münzkontakt klebt und so eine Kredit Spule abbrennt . Der Lötanschluss kann dann gegen das Metall Gehäuse kommen und so ebenfalls eine Kurzschluss verursachen . Man kann das ganze Kreditwerk nach dem Lösen einer Zentralen Flügel oder Rändel Mutter abziehen . Das hat nur Einfluss auf die Wahl aber nicht auf den Ablauf von Platte Greifern und Auflegen . In sofern also ein schneller und Dankbarer Test .
Löst aber die AC Sicherung aus liegt der Fehler entweder im Wahlmotor Kreis oder im Korbmotor bzw. Plattenteller Motor Kreis . Dazu hier ein einfacher Test . Wenn die AC Sicherung auslöst und der Greifarm steht geöffnet über dem Platten Magazin diesen einfach ein paar Zentimter anheben von Hand . Dann betätigt man damit den Mikroschalter K8 untem am Greifarm . Dieser schaltet die Spannung zwischen Korbmotor und Plattenteller Motor hin uns her . Es muss also dann der Plattenteller Motor hörbar laufen bzw. nicht laufen wenn die Sicherung ausgelöst hat . Bei deiner Box ist ja der alte Platten Tisch verbaut so das auch wenn der Motor dreht der Teller erst dann dreht wenn der Tisch rüber geschwenkt hat . Von daher muss man hier genau schauen ob dann der Motor läuft oder nicht .
Soviel zum Sicheren Test ob es der AC oder der DC Kreis ist wo es Problem gibt . Fällt die Sicherung im DC Kreis gibt es eigentlich nur zwei Punkte wo das Problem stecken kann und auf Grund von deinem Plattentisch einen indirekten dritten .
So , so du bist also in Deutschland wo in etwa wenn ich Fragen darf führt dich dein Besuch hin ?
11.10.26 18:12
Thank you for the kind suggestions. I will have a good look at it when I get back and try to narrow down what's the problem with the fuse. Every time it blows it takes the 3.14 slow blow fuse and one diode out . We are going near Koln to Phantasialand for a few days and then one day in Koln. The last time I went to Phantasialand was about 45 years ago.
11.10.26 22:14
Die Diode zerlegt es also auch jedes mal wieder ? Dann Frag ich mal was hast du da als Ersatz eingebaut ? Eine 3A Universaldiode wie die 1N5404 oder ähnlich finde ich persönlich schon ein wenig knapp . Ich bevorzuge da eine 6A wie die P600K . Außerdem tausche ich dann gleich beide . Ich hab so den Verdacht das du dir da eventuell selber einen Fehler durch eine zu schwach Dimensionierte Diode Eingebaut hast .
Phantasialand in Brühl , bin ich sonst auch mindestens einmal im Jahr hin gefahren . Ist ja nur rund 130km von mir entfernt . Aber seitdem die auf Gewinnmaximierung setzen fühl ich mich als Gast da nicht mehr wirklich Wohl . Du wirst den Laden nicht wieder erkennen . Obwohl jetzt schon 38 Jahre in Betrieb ist die Vekoma MK-900 ( Crazy Bats ) immer noch mein Lieblings Coaster ohne VR Brille . Mein Tipp für die Bahn letzte Sitzreihe . Aber auch Taron ( Tipp Kopf an die Nackenstütze sonst bekommt man schnell nen Schlag in die Nackenwirbel im Beschleuniger ) , Black Mamba ( hat zwei Big Boy Seats für große Jungs ) und Winjas Fear&Force fahr ich sehr gerne auch wenn ich langsam meine Knochen Jammern Höre . Aber das nur am Rande , ich wünsche Viel Spaß .
17.10.26 21:46
Quote
Swen
We had a great time in Phantasialand. Thank you for the recommendations. We managed to get everything that we wanted to do done whilst we were there. The queues were not busy at all at this time of year. I think Taron was probably my favourite but they were all good. The only one they wouldn't let me on due to my height (too tall) was Black Mamba. My Wife's favourite was fear and force.
17.10.26 22:34
I managed to spend a bit of time on it today and isolate different bits. I think the fuse is blowing when it tries to initiate the main motor that turns the carousel. There is a spring belt on this motor. If I remove the spring I can turn the carousel by hand. I haven't seen the motor move at all yet.
In testing today the only time I got the fuse to blow was when I pressed the record selectors. Sometimes it was instant sometimes it was seconds later.
If I press the scan button the latch opens and moves the stop out of the way but it doesnt turn.
I've attached some pics. I also spent a bit of time on this PCB that in the top of the machine as some of the tracks looked pretty bad. All the connectors were cleaned, joints reflowed and continuity checked.
Focus tomorrow is going to be on the motor. Try to remove it and see if I can get it to turn.
The credit mechanism isn't connected, it's been in the bottom of the machine since I got it.
The diodes that I have been using are SR560
[photos.app.goo.gl]
18.10.26 04:12
Eins mal Vorweg , nach dem Bildern und Videos würde jeder Normale Schrauber sagen Zünd an das Ding . Sei Froh das ich nicht wegrennen will , Spaß an Herausforderungen habe und außerdem völlig Verrückt bin . grinning smiley
Aber die Nummer wird Blutig . Das wird viel Zeit und Geld verschlingen bis das Ding wieder vernünftig läuft . Vorausgesetzt du wirfst nicht vorher das Handtuch .
Also ein Schritt nach dem anderen . Der Motor mit der großen Feder als Kraftübertragung auf die Riemenscheibe treibt nicht das Plattenmagazin ( Korb ) an . Dieser Motor ist nur für die Wahl zuständig . Der Korb Motor sitzt von hinten durch die Wartungsklappe gesehen rechts oben in der Ecke . Gern ist der Antriebsgummi der die Kraft auf die Lauffläche überträgt Brüchig oder durch drehen des Korbes von Hand einseitig abgenutzt so das der Korb nicht mehr dreht . Bitte nicht den Korb von Hand drehen ! Das schleift in den Gummi eine flache Stelle .
Die Wahl ist ein Thema für sich und bleibt erst einmal von mir unbeachtet . Damit der Wechselmechanismus funktioniert ist eine volle Funktion der Wahl auch nicht nötig . Das kann man Prima von Hand Simulieren .
Die Box leidet unter so vielen Baustellen das ich wirklich nur eins nach dem anderen mit dir Abarbeiten kann . Vieles ist an dem Gerät ist aus der Not heraus zusammen Improvisiert . Buchse 4 der Wahl zum Beispiel . Ist nicht nur nötdürftig Repariert es sagt mir vor allem das dein Gerät an Steck Buchsen Karies leidet . Die Kelchkontakte in den Röhrensockeln sind Oxydiert und Brechen innerlich ab . Das wird eine ordentliche Bastelei das in stand zu setzen . Der Verstärker ist so verbastelt , das wird ein Kapitel für sich . Nicht unmöglich aber extrem viel Arbeit . Das muss alles geprüft werden .
Normal würde ich jetzt empfehlen die Maschine aus der Box zu nehmen und auf einen Tisch zu stellen . Das Netzeil kommt daneben und der 8 polige Oktal Stecker der Maschine wird am Netzteil eingesteckt . Dann lässt sich die Maschine nämlich ganz ausgezeichnet frei zugänglich von allen Seiten reparieren . Leide rist bei dir der Stecker 4 angelötet wodurch das nicht geht . Die Frage ist also Repariern wir erst das oder willst du dich im Gerät auf dem Boden weiter rumquälen ?
Du hast was von Pfund geschrieben von daher gehe ich mal von England aus was die Ersatzteilbeschafung wegen Zoll nicht vereinfacht . Ich such mal bei ebay GB und beim Englischen Teile Dealer was verfügbar ist . Wir brauchen dafür schonmal einen Stecker und eine Noval Röhrenbuchse . Wir werden wohl für die Reparatur der anderen Buchse ( 5 ) auch eine Buchse als Ersatzteilspender brauchen da es diese mit 10 Pins nicht mehr gibt . Ist da also was darin abgebrochen wovon ich nahezu ausgehe müssen wir das Reparieren .
Egal welchen Weg du bevorzugt es stimmen die Steuerzeiten deiner Nockenscheibe nicht . Daher wird wahrscheinlich auch dein Problem mit dem durchbrennen der Sicherung kommen . Fakt ist der Greifer liegt auf dem Teller so darf dein Korb nicht los fahren das ist technisch so gewollt . Dein Tonarm liegt aber auch nicht auf . Das sagt mir deine Nocke steht nicht Richtig auf der Achse . Ich hatte das weiter oben schon geschrieben diese Einstellung muss passen . Damit fangen wir also an . Lass den Greifer zurück über das Magazin ( Korb ) Fahren bis er dort in Endstellung ist . Das bedeutet der ist dann in Endstellung wenn die Greifklaue unten am Greifarm voll geöffnet ist . Nur in dieser Positon kann und darf der Korb los fahren .
[jukeboxparts.co.uk]
Ich kann keine passende Buchse ( female ) auf ebay UK finden . Gibt es bei euch einen anderes Kleinanzeigen Portal wie marktplaats in den Niederlanden oder Kleinanzeigen in Deutschland wo man sowas vielleicht bekommen könnte ?
18.10.26 09:00
Hallo Swen,
ich meine, dass man für Teile der Deutschen Wurlitzer eigentlich nicht außerhalb Deutschlands suchen muß.
Diese Laufwerke sind auch hier zu finden.
Ich habe gerade in der vergangenen Woche eines ausgeschlachtet und den Rest entsorgt.
Weitere warten noch auf ihr Schicksal.
Einen schönen Sonntag noch - Oliver
18.10.26 11:03
Hallo Oliver , im Grunde gebe ich dir Recht . Aber wenn der gute Mann in GB beheimatet ist dann ist es wohl einfacher so Teile in GB zu Suchen als die aus Deutschland mit Zoll Abwicklung nach GB zu schicken , oder ?
18.10.26 17:52
Hallo Swen,
mit dem Hinweis auf die Insel hast Du natürlich Recht.
Wir machen die Erfahrung, dass es immer wieder Leute gibt, die sich Teile von wer weiß woher bestellen, die oftmals in Deutschland zu finden sind.
Schönen Abend noch - Oliver
18.10.26 18:21
Thanks again. It looks like you were right about the cam not being aligned correctly as being the issue with the basket not turning and the fuses and diodes blowing. I'm not 100% sure it's still spot on but it's now in the position you were after and the basket does turn with the scan button. Pressing the select buttons seems to start the write process but it never seems to move very far and I've not seen the read process move yet. This does feel like progress though. I've attached some more pics and a video to
[photos.app.goo.gl]
18.10.26 21:23
Prima wir machen Fortschritte .
Also die Wahl funktioniert wie sie soll . Wahlstifte sind genug gesetzt , eigentlich muss der Korb nun von selber durch die geschlossenen Taumelkontakte im Selektor anlaufen und eine Platte suchen .
Ich hab gerade nur das Handbuch 1976 vorliegen . Schau mal ob der Korb los läuft wenn du den Ladeschalter rechts umstellst .
Ich hab die verwendeten Mikroschalter mit der Rolle daran in deinem Video gesehen . Die sind durch die große Rolle nicht gut geignet da sich die Schaltpunkte so nicht gut einstellen lassen . Alle drei Mikroschalter sollten die selbe Hebellänge haben . Sonst verschieben sich die Schaltpunkte und am Ende fehlt dir dann der eine oder andere Millimeter damit das Timing passt . So wie der obere Mikroschalter beschaffen ist sind die Original .
19.10.26 23:56
I've gone round in circles a bit tonight with it. I think I may be getting a bit further but it keeps blowing the diodes which then gives me funny results until I realise they have gone. I currently have SR650s in there ats that's what was in when I got it.
In an earlier post you mention that you use p600k diodes
These are the diodes that I am taking about. Are these the ones where you tend to use the p600k as they are very different spec from the sr650. If so I'll get hold of some to try and maybe that will give me a bit more stability whilst I continue to test.
20.10.26 02:22
In der Partlist steht das diese Dioden 1,75A / 125V haben . Was denn nun SR560 oder SR650 ? Egal die eine macht 6A/50V die andere 5A/60V . Es kann gut sein das diese obwohl da nur 30V anliegen zuviel für die Diode ist . Möglicherweise gibt es da auch Spannungsspitzen womit die SR nicht klar kommt . Hat ja einen Grund warum Wurlitzer da 125V Typen genommen hat . Dafür wurden ganz schlaue Leute bezahlt um das zu entwickeln .
Außerdem fehlt in der Schaltung noch ein 1uF Folienkondensator . Sieht man im Verstärkerplan aber leider steht nur die Kapazität im Plan nicht die Spannungsfestigkeit . Da muss ich erst einen Verstärker aus dem Keller holen und das dort ablesen . Den Kondensator sollte man auch wieder einbauen . Muss ja für irgendwas gut gewesen sein . Ich denke nicht das Wurlitzer die da eingebaut hat weil die gerade welche übrig hatten . grinning smiley
Ich nehm die P600K gern weil ich die am Lager habe und mir eben die 3A bei einer trägen Absicherung von 3,15A rein vom Denken her zu schwach erscheinen für den Fall einer starken Belastung . Denn die Sicherung löst erst bei 3,15A aus . Wenn da also 3,14A fließen ist vom Datenblatt her eine 3A Diode um 140mA überlastet . Die Sicherung löst aber noch nicht aus , erst bei 3,15A . Ich hoffe du kannst meinem Gedankengang folgen . Außerdem was soll der Geiz ? Eine 1N5406 ( 3A/600V ) , 1N5407 ( 3A/800V ) oder 1N5408 ( 3A/1000V ) kosten egal welche , 5cent . Eine P600K ( 6A/800V ) kostet 15cent . Wenn ich davon 100 Stück brauche schmerzt das im Geldbeutel aber bei zwei Stück ?
Kannst du mir mal mitteilen wann genau die Diode durchbrennt ? Eigentlich geht das ja nur wenn der Getriebemotor ( MM ) läuft . Der sollte also dann stehen bleiben . Bleibt der immer an der selben Stelle stehen muss ja genau dann was passieren was die Diode durchbrennen lässt . Vielleicht ist das ja wenn die Nockenscheibe mit der Raste auf 3 Uhr steht oder auf 12 Uhr . Dann könnte man mal schauen was an den Mikroschaltern hängt die sich an diesen Positionen befinden .
Fährt denn jetzt der Korb selber los und sucht nach gewählten Platten ? Hinweis : Stellung vom rechten Schalter .
20.10.26 16:50
Thanks Swen,
I am trying to get consistency and I just wasn't getting it yesterday. It was a little frustrating. I changed the mode switches and then just nothing seem to happen but I noticed that if I removed the stop latch the basket was rotating constantly until the stop latch was closed again. I didn't want to leave it in this state for long with power. I went back over your thread and had a look through the 75 manual I have.
I then started testing the switches around the cam and I was getting weird readings which suggested that they may not be working so I pulled off the whole tray (limited by the soldered cable) to allow me to test the switches. I then realised that I was getting the weird readings whilst the switch on the junction box that the micro switches were connected to was plugged in. Once I removed that the switches tested normally. With it plugged in there was continuity on some of the switches whilst they were in both states.
At the end of the session I went back and read up on the alignment of the cam and I still think I didn't have that quite right but I understand it better now. When I re-aligned it I noticed the diodes had gone again. I had already replaced them both once that evening.
Because they aren't always blowing the fuse it's hard to see if one or both is failing and at what point. So without knowing what state they are in they can throw off the tests. I thought if they are on the weak side replacing them with something more suitable my buy me a bit more consistency.
One other thing that I noticed last night that I couldn't explain was that on the amp there is a cancel button. I assumed this was the same as the cancel on the plug junction box inside of the machine just more accessible. Mine is showing as having continuity when it's both pressed and not pressed. Pressing the button does not seem to change the continuity on the two terminals on the back of it.
23.10.26 00:37
I've replaced the diodes and it seems a lot more stable now. I've added a video of where I am currently. It seems to be doing most elements but still not on its own so I think I still have a timing issue. I have managed to get some sound out of of it but it's very quiet but that's probably due to me not having any volunteer control
[photos.app.goo.gl]
23.10.26 02:48
Du drehst dich ein bisschen im Kreis mit deinen Schaltern . 2mm Unterschied in der Achslänge vom Hebel der Mikroschalter entscheiden im Getriebe ob der Tonarm einschwenkt bzw. frei gegeben wird oder nicht . Die müssen alle drei einen gleich langen Hebel haben und nicht einen mit Rolle und einen mit Bügel und Wölbung .
Platten sind genug vorgewählt das höre ich in deinem Video wenn der Korb dreht . Das Klick , Klick , Klick ist der Suchfinger der über die Wahlstifte läuft . Die Wahlstifte selber betätigen die so genannte Taumelscheibe . Die 4 Kontakte an der Taumelscheibe sorgen dafür das der Suchlauf startet .
Ich vermisse aber wenn deine Maschine läuft auch das Typische Geräusch wenn der Stift zurück geschlagen wird . Das passiert wenn die Nocke den Schalter auf 3 Uhr betätigt . Jetzt gibt es da ein Bauteil was ich nur schwer Beschreiben kann was für eine Vernüftigen Masse Kontakt auf die Hauptachse wichtig ist . Das ist im wesentlichen ein Federstahl Drahtbügel . Dieser wird unten auf dem Selektor gegen die Mittelachse verspannt . Fehlt der Draht löscht die Box nicht immer die Wahlstifte weil die Mittelachse in Nylon Lagern läuft und so keinen guten Kontakt zu Masse hat . Die Reset Spulen für die Wahlstifte holen sich darüber aber ihre Masse .
So sieht das Teil aus .
[shop.kleylein.eu]
Prüf Bitte ob diese Lösch Spulen arbeiten / ob der Draht bei dir noch verbaut ist .
Der Strompfad für den Korbmotor ist von Masse über einen der 4 Taumelkontakte , den Ladeschalter LS1,1 an Magnet M3 ( Rastmagnet ) . Du musst also zwischen Masse Chassis und Stecker 13 Pin 8 weiss/rot sobald ein Wahl Stift gesetzt ist Durchgang haben . Bitte Prüfen !
Von der Buchse 13 Pin 8 geht es dann an Buchse 14 Pin 8 und von dort zum Ladeschalter 1,1 . Kabelfarbe bleibt weiss/rot und hinter dem Schalter geht es weiter mit weiss/grün an den Fahrtaster 2 und an Buchse 12 Pin 9 . Ich nehm an das der Ladeschalter 1,1 Kontaktproblem hat . Das machen die gern und entweder reinigt man die von Hand in dem man sie zerlegt und sauber bürstet oder man ersetzt sie .
02.11.26 15:37
Thank you again for the detailed explanation. I've found the grounding tab. Mines more like a strip of metal than what you linked but it seems to do the same thing. I've checked ground on this and on the four wobble contacts and that's all good.
I've ordered 3 new micro switches of the right type so they are all consistent. They should come later this week
I've added another video of current state of play to the Google album. It's definitely pushing up the pins when selecting using the buttons but it never seems to start the read process.
03.11.26 02:04
Der Teil ist wichtig damit der Korb selbstständig den Suchlauf startet .
03.11.26 03:23
Ich hab mir die Flipperkontakt Lösung gerade mal angeschaut . Ich muss das erst noch Prüfen aber ich glaube diese Scheibe da unten hat keine gute Masse sofern sie überhaupt eine Verbindung zur Chassis Masse hat .
