Wurlitzer Atlanta II - what to do 27.09.26 18:05 |
Registriert - Registered: 9 Tage - Days Einträge - Posts: 5 |
Hi everyone, I picked up an Atlanta II when I sold a rowe Anni jukebox. It hadn't worked for years and they wanted it out of the way. I've been having a look at it and I'm at the point of either selling it on or parting it out at I don't see another cleaner option but thought I would post here first incase anyone had any ideas. I've struggled to find parts and information for it. I have a decent manual that although isn't specifically for this jukebox it's fairly close but I've not found any reference for the amp which I believe is an s74 amp. The amp is blowing fuses as one of the windings is shorted to the chassis. Getting it rewound seems to be about £220 which is more than I want to pay as there are probably further faults. The volume control has also been removed.
Has anyone got a reference for the s74 so I can work out the voltages that the transformer is meant to be supplying? Has anyone had any luck with using something modern to supply the different voltages or does it just get to difficult trying to get on top of noise?
I would much rather try to get it working if possible but I've been surprised at the lack of information on these
If anyone does have any ideas that would be appreciated
Re: Wurlitzer Atlanta II - what to do 27.09.26 23:19 |
Registriert - Registered: 21 Jahre - Years Einträge - Posts: 4.949 |
Informationen gibt es wie Sand am Meer aber nicht unbedingt auf Englisch .
Der Verstärker / Netzteil ist eigentlich ziemlich simpel aufgebaut . Welche Sicherung spricht immer an ? Bei der Netzsicherung kommt der Entstörfilter in die nähere Auswahl weil die eigentlich immer defekt sind . Beim Verstärker muss man unterscheiden zwischen Spannung für den Verstärker und Spannung für die Mechanik . Die Spannung für die Mechanik wird über zwei große Dioden ( roter Deckel , schwarzer Kühlkörper mit Isolierschlauch drüber ) gemacht . Die gehen schon mal kaputt vor allem wenn es Probleme mit dem Getriebemotor gibt und irgend so ein Spezialist die Sicheurngen 3,15AT überbrückt hat . Der Verstärker wird über einen Gleichrichter Betrieben der eigentlich völlig unproblematisch ist . Auch die Endstufe ist kein wirklich Ernst zu nehmender Gegner . Die besteht aus 2N3055 und BC 140 / 141 als Treiber . Also nichts Exotisches . Problem ist der Lautstärkeregler . Wenn der von der Platine ausgelötet wurde dann muss da eben ein Fernlautstärkeregler dran gebaut werden . Ist unter dem Strich einfacher als den Originalen zu besorgen der nicht mehr gebaut wird . Kommt außerdem von den Kosten nahezu aufs gleiche raus .
Man muss zwar einiges einfach Überholen aber letztlich sind das recht dankbare Boxen und die Atlanta 2 ist dazu auch noch Form und Farbtechnisch sehr schön wenn man dieses Bunte Design mag . Nur das ist halt eine Oma die braucht jetzt erstmal ganz viel Pflege weil die halt über 50 Jahre alt ist und da ewig keiner was dran gepflegt hat . Ersatzteile gibt es bei jukeboxparts.co.uk . in Mengen .
Re: Wurlitzer Atlanta II - what to do 28.09.26 00:48 |
Thank you for your advice and information about the amplifier
The fuse in the top of the picture is blowing. One side of the fise is connected to one of the outputs on the transformer and has a direct short to the amplifier chassis which is why I think the transformer either needs to be rewound or I need to remove the transformer and use separate power so that's it's safe.
Re: Wurlitzer Atlanta II - what to do 28.09.26 09:04 |
Klassischer Messfehler
, die Wicklung liegt mit der Mittelanzapfung auf Masse / Gehäuse . Somit hast du rein vom Messen her einen Kurzschluss zum Gehäuse von den Gewebe Ummantelten Leitungen weil der Widerstand der Wicklung so gering ist .
Entweder ist wie schon oben erwähnt eine der beiden Dioden durch oder irgendwas im Gerät zieht zuviel Strom so das die Sicherung durch brennt . Meistens ist es der Getriebmotor MM der zuviel Strom aufnimmt . Der Abrieb der Motorkohlen und das altes Fett vom Getriebe sind da die beiden Haupt Verursacher . Wenn man den Motor als Sicherung Zerstörer Identifiziert hat reicht es meistens diesen Auszubauen und den Kohlestaub darin zu entfernen . Hinweis , nicht die drei Getriebe Schrauben raus drehen , nur Lösen ( Größe 7 ) und von den beiden Anschlusskabeln ein Bild machen sonst läuft der Motor am Ende falsch herum und zerstört Mikroschalter am Getriebe oder Teile des Getriebes .
Re: Wurlitzer Atlanta II - what to do 28.09.26 10:13 |
Thank you Swen, that's amazing if I am just reading the transformer incorrectly. That gives me hope, i just stopped when I found that as I compared it to the other windings and other transformers that I have and they didn't seem to have the same short.
The fuse is blowing when not connected to the jukebox so I'll start testing the components in the amp starting with the ones you have suggested and report back.
Thank you.
2 mal bearbeitet. Zuletzt am 29.09.26 20:13.
Thank you.
Re: Wurlitzer Atlanta II - what to do 02.10.26 00:18 |
I've made some progress. Thank you again for taking the time to reply as I was heading down a rabbit hole after measuring the transformer incorrectly. One of the diodes had failed, after replacing that and not putting any strain though the amp it's not blowing the fuse.
The gripper arm picked up a record and then froze half way. I'll follow your advice and try to remove and clean the motor as a starter.
Re: Wurlitzer Atlanta II - what to do 02.10.26 02:40 |
Schön zu Hören das es vorwärts geht .
Je mehr ich zu sehen bekomme desto mehr keimt die Frage in mir auf was zur Hölle haben die mit dem Teil angestellt ?
Ich hoffe du hast die Soffitten und das Relais vom Verstärker entfernt und nicht der Vorbesitzer der auch den Lautstärke Poti raus geklaut hat .
Kleiner Tipp , der Plattenteller Tisch ist noch der alte mit Idler Rad der braucht zwei dicke Riemen damit der ordentlich läuft . Mit nur einem Riemen neigen diese Antriebe zum Leiern . Die neuern mit dem oben Liegenden Synchronmotor braucht nur einen dünnen Riemen .
Du solltest dir , wenn du schon Ersatzteile bestellst auch gleich die Nockenscheibe auf der Rückseite des Getriebes anschauen . Gern ist der Weichmacher raus und die Scheibe bricht am Anschraub Punkt ( zwei Madenschrauben ) und dreht dann auf der Achse durch . Das kann auch der Grund sein warum der MM Motor stehen geblieben ist .
Sofern du eine neue Nadel für das Original Wurlitzer System kaufen möchtest , gut gemeinter Rat , Lass es . Kauf lieber gleich ein neues System . Beim Nadel wechsel bricht gern der Haltesteg der Nadel aus dem System , diese hält dann nicht mehr .
Re: Wurlitzer Atlanta II - what to do 03.10.26 18:29 |
Thank you for your comments again. I'm slowly learning more about this machine.
The bulbs weren't there, I've got some more now but not fitted them whilst the fuse was blowing. The relay on the amp was also missing but I've found one in the bottom of the machine which I think is the right one. Also not fitted yet.
Thank you for the note on the additional belt. Hopefully I can get it to the stage where I am worried about the sound wobbling.
I spent a bit more time with it today. The cam was slipping. I took it out and did a temporary repair whilst I try to track down a replacement. When I put it and turned the jukebox on, the gripper arm returned to the carousel. I was unable to make a choice, when I pressed the buttons they stayed in, there was a noise from the carrasel but no movement. I think I then moved the cam a bit and the arm moved to the record down position and the turntable started spinning. I placed a record on the turntable but there was no sound. At this point I was unable to cancel it either by moving the tone arm or by pressing either cancel switch.
I guessed this may be due to the cam not being aligned properly. I loosened the cam and got it to return but struggled to figure out what the proper alignment should be. I then started to turn the cam whilst it was loose to see if I could work out what the alignment should be and at that point it blew the diode and fuse again.
I think the next step is to work out how to align the cam and get a replacement cam. Fit it on the correct alignment and then see how it behaves from there
Re: Wurlitzer Atlanta II - what to do 04.10.26 11:57 |
Ein bisschen Basis Wissen .
Die Soffitten auf dem Verstärker haben 6V 18W später Verstärker haben 24V 18W . Die Liegen von der Schaltung her in der Lautsprecher Leitung . Wird dem Verstärker zu viel Leistung abverlangt durch eine zu niedrige Impendanz der angeschlossenen Lautsprecher oder einem Kurzschluss in der Lautsprecher Leitung fangen diese Soffitten an zu Leuchten und sollen so den Verstärker schützen . Fehlen diese kann aus dem Verstärker nichts raus kommen . Das ist so als wenn die Lautsprecher nicht eingesteckt wären .
Das Relais schaltet die Spannung für den Verstärker ein . Das passiert jedesmal wenn die Kerbe an den Nockenscheibe die obere Position erreicht . Daher kommt letztlich auch das Dt. Wurlitzer typische "Fump" Geräusch wenn der Verstärker zu schaltet . Insgesammt hat dieses Modell drei Relais . Eins für den Verstärker ( das ist bautechnisch das größere der V23154 Serie ) . Eins für die A-B Seiten Bestimmung auf dem Chassis vor dem Greifarm und ein weiters auf der kleinen Platine oben an der Tastatur . Die beiden letzen Relais gehören zwar auch zur V23154 Serie sind aber deutlich kleiner . Ich hab hier schon mehrmals Ausfürlich darüber geschrieben was die ganzen Zahlen und Nummern auf den Relais zu Bedeuten haben um Ersatz zu beschaffen . Leider haben es diese Informationen noch nicht ins Archiv geschafft .
Daher hier mal den Link zu einem Beitrag wo es auch um die V232154 geht .
[forum.jukebox-world.de]
Zur Info , du brauchst um oben an die Tastatur zu kommen den Gehäuse Schlüssel WUA 1 . Ich meine mich zu erinnern das die untere Rückklappe auch ein Schloss hat , da passt der Gehäuseschlüssel ebenso . Den WUA 1 kannst du bei sämtlichen Jukebox Parts Dealern nach kaufen .
Zum Thema Nockenwellen Scheibe , Bitte mal diesen Beitrag durchlesen .
Die Scheibe auf dem Bild ist nicht in Ruhestellung Fotografiert . Damit die Steuerzeiten passen muss die Greifklaue unten am Greifarm völlig geöffnet sein wenn der Greifarm über dem Platten Magazin steht . Dann ist der untere Mikroschalter K6 betätigt . Obwohl das ganze sehr Grob aussieht kann es sein das die Scheibe leicht vor oder nach Justiert werden muss . Das kann man aber letztlich erst sehen wenn die Maschine komplett läuft weil erst dann geprüft werden kann ob man die Richtige Grundstellung getroffen hat . Hat man das nicht gibt es Probleme mit dem Tonarm . Dieser hebt dann nicht ab , schaltet am Ende nicht oder wird nicht frei gegeben . Such dir was aus es gibt da viele Fehlerbilder wenn diese Verdammte Nocke nicht Richtig steht .
Nochmal zum Verstärker , geh davon aus das du den Überholen musst und eine Neu Einstellung von Symetrie und Ruhestrom Nötig ist . Aber das ist ein Thema für sich das sollten wir dann in einem neuen Beitrag abarbeiten . Auch müssen dafür ein paar Grundkenntnisse vorhanden sein was Meßtechnik angeht und der Umgang mit Lötzinn , Lötkolben und elektronischen Bauteilen .
