Rock-Ola 476 – Random 32V mechanism breaker trips, LED #1 off during play 07.06.26 21:03 |
Registriert - Registered: 5 Monate - Months Einträge - Posts: 5 |
Hi all,
I am troubleshooting a Rock-Ola 476 and would appreciate some guidance from anyone familiar with these machines.
The problem is the 32V mechanism circuit breaker (red breaker on the power supply) trips randomly during playback.
Symptoms:
* The machine powers up normally.
* The magazine scans correctly.
* The gripper picks up and transfers the record correctly.
* The record is placed on the turntable and playback starts normally.
* The fault never occurs during magazine movement or gripper transfer.
* It only occurs while the record is already playing.
When the fault occurs:
* The red 32V mechanism breaker trips.
* LED #1 on the power supply immediately goes out.
* LEDs #2 and #3 remain on.
* All 32V functions stop.
* The amplifier and other low-voltage functions appear to remain powered.
The strange part is that the trip is completely random:
* Sometimes it trips after 10–15 seconds of playback.
* Sometimes it plays an entire record.
* Sometimes it survives one record and trips during the next.
* There is no obvious relationship to Side A or Side B selections.
Additional observations:
* The gripper motor was previously found mechanically jammed.
* I manually returned the gripper mechanism to its park/home position.
* Since then the transfer mechanism operates normally.
* The gripper motor does not feel unusually hot.
* No unusual noises are heard before the breaker trips.
* The only sound is the breaker itself tripping.
After resetting the breaker:
* Playback immediately resumes.
* The turntable continues normally.
* However, when the record reaches the end, the mechanism does not complete the next transfer cycle correctly and the gripper appears out of synchronization, requiring manual correction.
I have already:
* Checked all visible fuses.
* Reset the circuit breakers.
* Inspected the mechanism for obvious mechanical binding.
Questions:
1. Are nuisance trips of the 32V breaker common on these machines due to breaker ageing?
2. Is there a known 32V load that commonly develops intermittent overcurrent faults?
3. Could a faulty Play Control relay or relay socket cause this type of random breaker trip?
4. Is there a recommended procedure for isolating 32V loads one by one to identify the culprit?
Any suggestions on where to look next would be greatly appreciated.
Thanks in advance.
Symptoms:
I have already:
Questions:
Thanks in advance.
Re: Rock-Ola 476 – Random 32V mechanism breaker trips, LED #1 off during play 07.06.26 21:29 |
Registriert - Registered: 12 Jahre - Years Einträge - Posts: 152 |
Hi Tabion
Have you considered the mechanism circuit breaker?
It's possible that's the problem. Try replacing it.
I had one that was faulty also.
Ruedi
Ruedi
Re: Rock-Ola 476 – Random 32V mechanism breaker trips, LED #1 off during play 07.06.26 21:56 |
Thanks for the suggestion!
That’s actually becoming one of my main suspects. The trip is completely random and never seems to be associated with a specific mechanism movement. The machine can play for a few seconds, an entire record, or even start a second record before the breaker trips.
Do you happen to know the rating and part number of the original mechanism breaker, or a suitable modern replacement?
Re: Rock-Ola 476 – Random 32V mechanism breaker trips, LED #1 off during play 07.06.26 23:24 |
Registriert - Registered: 7 Jahre - Years Einträge - Posts: 1.630 |
Check Sequence #16 in the manual.(Micro#3 and subsequent breaking circuit) If the gripper motor is not switched off before the mechanical end position, the circuit breaker will switch off with some delay during the play cycle.
Rgds Jürgen
Rgds Jürgen
Re: Rock-Ola 476 – Random 32V mechanism breaker trips, LED #1 off during play 07.06.26 23:45 |
Registriert - Registered: 21 Jahre - Years Einträge - Posts: 4.921 |
Prüfe ob der Gripper Motor nach dem Auflegen noch unter Spannung steht . Einfach unten am Wellenzapfen vom Motor drehen ob der Motor Freigängig ist . Wenn nicht ist wahrscheinlich das Reed Relay K403 ( 24V ) auf dem Logic Board defekt .
Du kannst auch mal selber mit der Forum Suche nach dem Problem Suchen . Ist x mal Beschrieben da alle Rock-Ola der MAX Generation wie 477 , 478 , 481 usw. darunter leiden .
Re: Rock-Ola 476 – Random 32V mechanism breaker trips, LED #1 off during play 08.06.26 00:21 |
Thanks, this is very interesting.
The gripper was previously mechanically jammed and I had to manually return it to the home position using the manual shaft on the gripper motor.
Your explanation would certainly fit the symptoms, especially because the breaker never trips during the transfer cycle itself, only after a delay while the record is already playing.
I will check Micro #3, verify whether the gripper motor remains energized after the record has been placed on the turntable, and investigate reed relay K403 on the logic board.
One additional question: does anyone know a current source or suitable replacement for the Allied Controls relay used in these machines?
The relay fitted in my jukebox is:
ALLIED CONTROLS
T362 C-C-2 / 24V
485/485 CONT 2A
If anyone knows of:
* a supplier for the original 24V relay,
* a NOS source,
* or a modern equivalent that can be adapted,
I would greatly appreciate the information.
Many thanks for your help.
ALLIED CONTROLS
T362 C-C-2 / 24V
485/485 CONT 2A
If anyone knows of:
* a NOS source,
Re: Rock-Ola 476 – Random 32V mechanism breaker trips, LED #1 off during play 08.06.26 11:20 |
Das K403 ist ein handelsübliches Reed Relais . Die blaue runde Bauform sieht ein wenig merkwürdig aus und ist mit ihrer einreihigen Anschluss Kontakt Anordung heute nicht mehr ganz geläufig aber es gibt sie noch . Wenn man sich die Platine anschaut kann man am Layout erkennen das Rock-Ola diese damals schon für Reed Relais im Standard IC Gehäuse Format ( DIL /DIP ) vorgeplant hat . Einziger Haken an der Geschichte ist das diese teilweise je nach Hersteller und Typ durch kontaktierte Anschlüsse haben und so beim Einlöten einen Kurzschluss verursachen . Man muss da letztlich also vorher einmal ausmessen wo solche Brücken verbaut sind und diese nicht benötigten Beinchen einfach abschneiden . Ich schau mal ob ich nacher dazu komme noch ein paar Fotos einzustellen .
Re: Rock-Ola 476 – Random 32V mechanism breaker trips, LED #1 off during play 08.06.26 13:34 |
Hallo Swen, die 476 hat kein K403, es gibt nur ein Reed Relais K401 auf dem Logic Board, das wird durch Micro 1 geschaltet und signalisiert dem Controller dass der Greifer losgelaufen ist. Das Stoppen des Greifermotors nach dem Auflegen der Platte erfolgt, soweit ich das verstehe, komplett autark auf dem Mech Controller.
Re: Rock-Ola 476 – Random 32V mechanism breaker trips, LED #1 off during play 08.06.26 17:08 |
Wenn da dieses Board noch drin verbaut ist . Vielleicht ist das aber auch schon mal durch das mit den drei Reed Relais ersetzt worden . Who knows
Re: Rock-Ola 476 – Random 32V mechanism breaker trips, LED #1 off during play 08.06.26 17:27 |
Vielen Dank für die Klarstellung.
Meine Maschine ist tatsächlich eine Rock-Ola 476 und auf der Logic Board befindet sich nur das Reed-Relais K401, kein K403.
Im Rahmen der Fehlersuche würde ich gerne sowohl das K401-Reed-Relais als auch die Mikroschalter als mögliche Fehlerursachen ausschließen.
Kann mir jemand eine Bezugsquelle für einen Ersatz des K401 nennen? Ich wäre interessiert an:
* einem Originalteil,
* einer NOS-Quelle (New Old Stock),
* oder einem modernen Ersatz, der bereits erfolgreich in einer Rock-Ola 476 verwendet wurde.
Außerdem wäre ich dankbar für Informationen zu passenden Ersatztypen der Mikroschalter im Greifermechanismus, insbesondere für Micro #3, der bereits erwähnt wurde.
Bevor ich beginne, Teile auszutauschen: Gibt es eine einfache Möglichkeit, das K401 und den Micro #3 mit einem Multimeter zu testen, während sie noch in der Maschine eingebaut sind?
Falls jemand Teilenummern oder europäische Bezugsquellen empfehlen kann, würde ich mich sehr freuen.
Vielen Dank nochmals für die Hilfe!
Re: Rock-Ola 476 – Random 32V mechanism breaker trips, LED #1 off during play 09.06.26 10:59 |
Ich hatte geschrieben, dass das Stoppen des Greifermotors autark abläuft. Das ist im Prinzip auch korrekt, zuvor muss aber die Latch Spule stromlos schalten, genau das erfolgt über K401. Ob K401 korrekt funktioniert, sieht man an der "Index Led". Diese muss ausgehen sobald der Greifer losläuft und K401 über Micro1 geschaltet wird. (im Bild rot)
Wenn Micro 3 nach dem Auflegen der Platte schaltet muss die "Music Cycle Led" angehen. (im Bild blau). Wenn bis dahin alles korrekt funktioniert und der Greifermotor trotzdem weiterläuft geht die Suche bei K301 weiter.
Hast du zwischenzeitlich geprüft ob der Motor wirklich nicht abgeschaltet wird ?
1 mal bearbeitet. Zuletzt am 09.06.26 14:21.
Re: Rock-Ola 476 – Random 32V mechanism breaker trips, LED #1 off during play 10.06.26 10:14 |
Hier mal ein Bild vom Reed Relais Ersatz für das K403 . Im Grunde sehen die Ersatz Typen für die anderen Relais genau so aus haben nur eine andere Spannung .
Ich bin mir nur nicht Sicher ob in dem Kreis wirklich der Fehler liegt . So ganz Treffsicher ist die Auto Übersetzung nämlich nicht . Für mich ist bis jetzt noch nicht geklärt ob der Gripper Motor sich fest läuft oder nicht . Läuft sich der Gripper fest bzw. steht der die ganze Zeit unter Spannung wenn die Platte schon längst aufgelegt ist kann man die Spannung unterbrechen indem man den On-Off-Oper Schalter einmal auf Off und wieder einschaltet . Dann fällt die Spannung auch ab . Im Umkehrschluss bedeutet das aber auch , schaltet man die Box von Oper auf Off um an den Motor zu kommen und dann wieder ein ist der Motor auf jeden Fall ohne Spannung . Man baut sich also selber einen Fehler in den Prüfvorgang .
