How to connect rock ola rectifier 01.04.26 13:42 |
Registriert - Registered: 15 Jahre - Years Einträge - Posts: 126 |
Hello everybody,
I have a rock ola 444 and it's missing the rectifier in the power supply.
I have a new one but what color wire goes where?
I have the manual but it's missing the power supply schematic.
Best regards,
Tim
Best regards,
Tim
Re: How to connect rock ola rectifier 01.04.26 14:11 |
Registriert - Registered: 21 Jahre - Years Einträge - Posts: 1.450 |
Hi Tim,
it's not the manual missing the power supply schematic - it's you missing the large wiring schematic diagram for model 444.
In the service manual itself Rock-Ola "only" printed the sequences of operation and the amplifier schematic.
I attach an excerpt of the power supply schematic showing the rectifier.
Hildegard Stamann
Hildegard Stamann
Re: How to connect rock ola rectifier 01.04.26 15:12 |
Re: How to connect rock ola rectifier 01.04.26 15:57 |
I've disconnected everything from the power supply and placed the new rectifier.
The problem is that the right 3 amp DC fuse blows when i turn the power supply on.
Re: How to connect rock ola rectifier 02.04.26 20:32 |
Registriert - Registered: 21 Jahre - Years Einträge - Posts: 4.842 |
Ich muss erst nach dem Schaltplan schauen aber schonmal vorab . Bist du Sicher den Gleichrichter Richtig angeschlossen zu haben ? Die neuen Gleichrichter haben nicht immer die selbe Belegung wie die Originalen .
Re: How to connect rock ola rectifier 03.04.26 08:26 |
Yes i have 35v dc output on the rectifier
Re: How to connect rock ola rectifier 03.04.26 10:15 |
Registriert - Registered: 7 Jahre - Years Einträge - Posts: 1.566 |
Hello Tim,
I don`t have the 444 schematic, but usually the +33V and -33V supply has electrolytic filter caps.
They can fail shorted.
Rgds...Jürgen
Rgds...Jürgen
Re: How to connect rock ola rectifier 03.04.26 11:57 |
Deine Aussage 35VDC lässt bei mir alle Alarmglocken läuten .
Die Schaltung funktioniert mittels Mittelabgriff am Transformator . Am Gleichrichter liegen 78VAC an . Durch den Mittelabgriff dieser Wicklung an Masse bekommt man die 32VDC negativ und 32VDC positiv gegenüber Masse gemessen . Wenn du da also nur 35VDC Messen kannst ist es sehr wahrscheinlich das da was nicht stimmt .
Meistens sind diese Gleichrichter mit Kabelschuhen angesteckt so das ein Löten nicht nötig ist . Daher zieh mal plus und minus vom Gleichrichter ab und Messe dann jeweils minus und plus gegen Gehäuse Masse . Dein Meßgerät sollte einmal +32VDC und einmal -32VDC anzeigen . Sofern die Sicherungen das Überleben .
Melde dich was deine Messung ergibt , dann sehen wir weiter .
@Jürgen
Siebelkos sind an dieser Stelle noch nicht verbaut . Die kommen erst im Verstärker . Wenn er also alle weiteren Verbindungen gelöst hat ist ein Elko Problem erst einmal nicht wahrscheinlich .
@Jürgen
Re: How to connect rock ola rectifier 03.04.26 12:55 |
The new rectifier was bad
I replaced it with another one and replaced diode 23 on the playrelais.
The jukebox is working fine again.
Tim
Tim
Re: How to connect rock ola rectifier 03.04.26 13:59 |
Ahhh , klassischer Fall von Montags Gleichrichter .
