Wurlitzer 3600 not canceling selections correctly 15.02.25 00:22 |
Registriert - Registered: 5 Jahre - Years Einträge - Posts: 29 |
Hello, I have a Wurlitzer 3600 that everything seems to work on it except an issue with canceling the accumulator latch pins sometimes. When I select a song the latch pin will be popped up everytime but sometimes when the cancel solenoid plunger goes down to cancel the pin it slides to the side of it and gets hung there. So when that record is done playing and returned it just picks it back up and plays it again because the latch pin is still in the up position stuck on the cancel solenoid plunger. I have noticed the cancel solenoid plungers are not centered with the latch pins like I feel like they should be and it seems the solenoid plunger can move enough and slide off of the latch pin. To fix this issue is it as simple as adjusting the cancel solenoid like in the manual by adjusting the readout arm screw? Is there a way you can post a picture on here. I was going to post a pic of that section of the manual. Thanks
Re: Wurlitzer 3600 not canceling selections correctly 15.02.25 05:12 |
