Eltec F60 cartridge
31.01.25 07:52
Can anyone advise on the correct wiring for the Schumann-Merula SK451 fitted to an Eltec F60? There's 2 pins on the cartridge but 3 wires on the tonearm.
Also, does anyone know of a suitable replacement cartridge?
Re: Eltec F60 cartridge
03.02.25 22:07
Maybe this Ronnette ST105 could work. It is a double-sided stereo ceramic one but can be connected for mono of course.
There are dimensions here to compare if it would fit in Eltec F60:
In general I assume that one wire is for ground and then probably the other two go to the pins. As the Schumann-Merula SK451 is a double-sided one, there might be one pin for each side.
Was any cartridge already connected and if so how?
Maybe you can send photos so we can see better what you have.
Kind regards - Hildegard Stamann
05.02.25 21:12
Hi, thanks for the reply. It came with a stereo Ronnette double sided cartridge made to fit. The earth wire went to one pin & one of the other wires connected to another pin, the other 2 pins were not connected. The third wire was cut. The jukebox hasn't worked for over 40 years. I've got all the mechanicals working, but no sound.
I purchased an F100 manual, but the wiring diagrams don't include the tonearm.
Ideally I wanted to fit the correct cartridge, but I may buy the one you mention as it is similar to the one fitted, and at least I'll know it works.
