Wurlitzer new Orleans dead scc, cd mech etc 18.09.24 00:57 |
Registriert - Registered: 1 Jahr - Year Einträge - Posts: 10 |
Good day, this is my first post.
I'm a novice unfortunately and bought this pinball as a non working project, I have been reading up and trying to repair myself but could do with some help I'm afraid.
The jukebox compact amplifier 40 200 000 00 functions, LEDs red and green illuminated and I can hear a buzz from the speakers, unfortunately after connecting an MP3 to the input the amplifier does not produce any sound.
The strip lights illuminate ok
The front panel flip charts move left to right when operating the buttons for left and right but that's all that appears functional.
I found an old wiring diagram for a similar model I believe.
I have first checked at the scc cd2500 module as there are no functioning LEDs on the front.
I have 32vac present and two 12vdc reading 11.85v DC
I have opened up the cover and checked the 7805 voltage regulator at the bottom of the board, getting just over 12v DC in and an output of 5.11vdc
From there I'm stuck, is there only other power inputs to the scc, or any other reason why it won't power up.
The display that it drives is also non functioning.Also the coin mech is missing but that wouldn't cause this issue? I also noticed what looks like an adapter board that has two very burnt resistors but the voltage to the scc is there. I not sure if this is related
Can you help?
Can you help?
Re: Wurlitzer new Orleans dead scc, cd mech etc 18.09.24 11:32 |
Registriert - Registered: 21 Jahre - Years Einträge - Posts: 4.916 |
Pinball ? Du meinst doch Sicher Jukebox .
Die SCC funktioniert seit 1979 im Grunde gleich und man kann mit d em passenden Programm jede alte SCC durch eine neuere Ersetzen . In sofern sind aiuch die Pläne zumindest was die Anschlüsse anbelangt weitgehenst gleich nur das die neueren SCC für CD benutzung einen RS 232 Ausgang haben .
Wenn du den Stecker für die Korblichtschranke abziehst dann sollten LED K und Z leuchten . Wenn nicht hat die SCC schonmal ein Problem wahrscheinlich mit der Spannungsversorgung . Die SCC bekommt die Spannung über den zweiten Stecker von unten auf der linken Seite . Hier liegen einmal um die 30VDC und zweimal 9VAC an . Bei den späteren kann es sein das man dort schon GLeichspannung genommen hat was aber egal ist da du die 5V für die Logic der SCC ja anliegen hast .
Wenn du die Korbraste vorne rechts am Korb von Hand drückst sollte der Korb losfahren und die LED Z und K anfangen im Takt zum Korb zu Blinken . Eine davon ist für die Darstellung des Zählimpulses vom Korb die andere für den Sync Punkt ab wann gezählt wird ( leuchtet nur einmal je Korbumdrehung ) . Welche jetzt was macht hab ich gerade nicht im Kopf .
Je nach E-Prom Version läuft die Einschaltroutine etwas anders ab . Es gibt eine Version welche erst nach dem Einschalten den Korb einmal Rotieren lässt und erst dann das Display ansteuert . Sehr nervig für den Techniker da man nie auf Anhieb sehen kann ob die SCC arbeitet oder nicht . Von daher nimm nicht das Display als Indikator das die SCC läuft .
Aus welchem Land kommt die Box ? Ich Frage da sich dein Englisch sehr nach England direkt anhört . Hintergrund ist das ich vor 10 Jahren mal eine ganze Kiste mit defekten SCC aus England gekauft hatte . Beim Reparieren ist mir dann aufgefallen das über die hälfte ein defektes E-Prom hatten . In dem Sinne waren die also eigentlich nicht wirklich kaputt sondern das E-Prom war einfach schlecht gebrannt . Da bekomm ich jetzt die Kurve zu England . Nicht das du auch eine dieser SCC da vorliegen hast mit einem schlecht gebrannten E-Prom . Nur so eine Idee .
Ansonsten kann dir aber Kai ( aka Catboy ) dazu bestimmt noch mehr sagen , der steckt da tiefer in der Materie .
Re: Wurlitzer new Orleans dead scc, cd mech etc 18.09.24 11:41 |
Wow thank you so very much. Very helpful information.
I'm located in Portugal but the jukebox is originally from France I think as the credits say francs.
This morning I was fiddling with the machine. I closed a micro switch called k8 and then opened the carousel switch and the basket turned and as you said the two red LEDs on the scc flashed in sequence.
But that is all, I have a feeling the switches on the mechanisms might be set incorrectly.
Re: Wurlitzer new Orleans dead scc, cd mech etc 18.09.24 12:19 |
Re: Wurlitzer new Orleans dead scc, cd mech etc 18.09.24 17:15 |
Thank you. Are switches k7 and k8 normally open or closed. They are both open currently with the cd grab arm in the vertical position.
Re: Wurlitzer new Orleans dead scc, cd mech etc 18.09.24 23:50 |
K7 wird betätigt wenn der Greifarm über dem Magazin steht und völlig geöffnet hat .
Wo K8 sitzt kann ich dir aus dem Kopf heraus nicht sagen .
Re: Wurlitzer new Orleans dead scc, cd mech etc 19.09.24 02:24 |
Thank you.
The bar was bent causing switch k8 to be open in the wrong position. Switch k7 has a crack, I noticed only when opening the link you sent me so I'll be ordering one of those.
Ok, when turning on the carousel does not turn I I manually open the latch it turns and I get the red LEDs operate on the scc.
Unfortunately after 2 turns the display does not operate, I read this could be caused by a bad c22 capacitor on the scc board?
I've had a look, c22 is a tiny ceramic disc capacitor top right of the board?? Or is it a different component?
Also I think tomorrow I will reseat the chips and check the back of the board for corrosion.
Thank you so much for your help.
Oh, I said pinball in my first post, that's because I restored a couple for my house. Sorry....
Re: Wurlitzer new Orleans dead scc, cd mech etc 19.09.24 10:10 |
C22 ist ein Elko bei den alten SCC für den Reset Schaltkreis . Bei den neueren SCC hat der eine andere Position .
Welche E-Prom Version ist verbaut ? Ich könnte mal schauen ob ich die habe und dir dann die Checksumme mitteilen . Wenn du dann dein E-Prom prüfst kann man sehr schnell sehen ob es evt. ein E-Prom Problem ist .
Re: Wurlitzer new Orleans dead scc, cd mech etc 19.09.24 13:14 |
How do I tell the Eprom version, I cannot get the display to work at the moment.
I've attached some pictures which might help.
Thank you.
Thank you.
Re: Wurlitzer new Orleans dead scc, cd mech etc 19.09.24 23:09 |
Wenn die Box ordentlich gewartet wurde steht die E-Prom Version unten rechts auf dem Kunststoff Deckel der SCC . Ist aber schon wieder merkwürdig das die nicht auf dem E-Prom selber steht .
Re: Wurlitzer new Orleans dead scc, cd mech etc 20.09.24 11:35 |
Re: Wurlitzer new Orleans dead scc, cd mech etc 20.09.24 19:34 |
Registriert - Registered: 21 Jahre - Years Einträge - Posts: 668 |
Let me join in...
The capacitor for the reset has got a new designator for CD SCCs. It is now labelled CR1 (220uF) and should be located right above the lithium battery.
Please check if that capacitor has turned into a dead short.
-Catboy
-Catboy
Re: Wurlitzer new Orleans dead scc, cd mech etc 20.09.24 20:24 |
Yes this cap above the lithium battery.
It does indeed have a dead short, thank you.
I'll get one ordered and replace, is there any other caps I should replace on this scc?
Thank you so much
Thank you so much
Re: Wurlitzer new Orleans dead scc, cd mech etc 21.09.24 12:05 |
Registriert - Registered: 7 Jahre - Years Einträge - Posts: 1.630 |
Just a general comment.If you don't have an in-circuit ESR meter and some experience to judge the electrolytic capacitors in the power supply, replace them. Bad filter capacitors can cause erratic failures as the supply voltages become unstable with changing load conditions. Even shorts glitches you don't see with a multimeter can corrupt the digital circuit's operation.
Rgds Jürgen
Rgds Jürgen
Re: Wurlitzer new Orleans dead scc, cd mech etc 21.09.24 14:49 |
Yes good advice.
I do have a means if testing a capacitor out of circuit but after removing I may as well fit a new one.
Thank you
1 mal bearbeitet. Zuletzt am 21.09.24 17:13.
Thank you
Re: Wurlitzer new Orleans dead scc, cd mech etc 27.09.24 20:07 |
Ok a little further, I replaced two 220uf 63v caps and also the large 2200uf 50v
Now when powering on I now get a display on the front panel that only shows a 0
The cd arm immediately starts up and goes through the process of picking up a cd, putting it on the cd player and immediately puts it back.
It just keeps repeating this action.
I can't seem to get it into service mode either, I think I have it set to free play.
Little by little more is coming to life.
Thank you for your help up to now.
Re: Wurlitzer new Orleans dead scc, cd mech etc 28.09.24 02:19 |
Re: Wurlitzer new Orleans dead scc, cd mech etc 28.09.24 17:46 |
Serial number is 3107 but scc is that model so I'll change transistors anyway.
Thank you I wasn't aware of this problem.
