schematics on amp for Arietta Pickolo
geschrieben von - posted by jukeboxjanne
13.09.20 11:14
Where can I find schematics on amp for Arietta Pickolo ?
Re: schematics on amp for Arietta Pickolo
13.09.20 14:54
Hello Janne????
Everybody appreciates if you introduce yourself a little bit first. This gives discussions regarding our hobby a slightly personal touch.
Regards PitinWHV.
13.09.20 20:14
Hello jukeboxjanne,
welcome here.
It seems there are different amps used in Arietta Piccolo. Which one is installed in yours?
In best case you'll have an ID plate on the amp with a model ID. If not upload a photo here - max 150 kB - and inform which valves are mounted.
Regards, Hildegard Stamann
14.09.20 08:23
The problem is that the amp is missing, so I will build one, the schematics will ev show how eq was made so it sounds as close to org. as possible.
So, a schem on any model will do.
14.09.20 08:31
Hello jukeboxjanne,
these amps are around.
I suggest to place a wanted ad in our classified online market.
I'm sure you will get offers.
It always helps to show a photo.
You may use the one attached.
Kind regards - Oliver Stamann
14.09.20 20:33
Hello jukeboxjanne,
please send any message to us directly by email using our one and only address: stamann@jukebox-world.de
Don't send messages through the forum.
Thanks and kind regards - Oliver Stamann
