amp 41710-A 02.10.19 13:15 |
Registriert - Registered: 7 Jahre - Years Einträge - Posts: 137 |
Hi all
need to pick your brains again,in the rockola 41710-A amp there is a component (cap) across the input socket terminals, there is no value marked on it only these numbers,1346531//35386 ,as one of the leads has broken off i need to replace it ,can anyone tell me what to replace it with, it is not shown on the amp schematic , it has 3 connections the two outer across the input socket (L++R) the middle to chassis
any help please
mick
any help please
mick
Re: amp 41710-A 02.10.19 14:13 |
Registriert - Registered: 19 Jahre - Years Einträge - Posts: 26 |
Hi Mick
Per channel is a 220 k resistor with a .001 MFD capacitor in series with a 1 M resistor parallel.
Greetings,
Erwin
Greetings,
Erwin
Re: amp 41710-A 02.10.19 16:10 |
Hi Erwin
thanks, does this mean all the 3 components you mention are coimbined in the one unit as there is just the one piece in-situ in the amp, which of the connections in your reply is grounded as the one in the amp has a ground, could you make a sketch of the connections please,
cheers
mick
1 mal bearbeitet. Zuletzt am 02.10.19 18:51.
cheers
mick
Re: amp 41710-A 02.10.19 18:53 |
Registriert - Registered: 10 Jahre - Years Einträge - Posts: 523 |
Hi Bopper,
there are six parts combined in one module. In my schematic the P.E.C. 35386 is shown with 680k instead of 1M.
Regards,
Regards,
Re: amp 41710-A 02.10.19 21:32 |
Hi Jens
thanks for that info and drawing i now understand and can now see it in my schematic, how do they incorporate 6 parts in a small module ? , again a big thanks for sorting out my problem, one thing do you know what is the wattage of resistors is a 1/4 watt ok so i can order the bits
cheers
regards
mick (bopper)
cheers
regards
mick (bopper)
Re: amp 41710-A 03.10.19 21:03 |
Hello Mick,
there is almost no power dissipated in those resistors, so 1/4W types are ok.
You can try to fix the PEC by grinding off the ceramic around the broken pin and solder a new wire to it.
Rgds Jürgen
Rgds Jürgen
Re: amp 41710-A 03.10.19 21:26 |
HI Jurgen
hope your keeping well, i will have a try at your suggestion otherwise i will install one using the drawing and components,thanks for the help, just remembered, my last posting which you helped me with about my other amp ,i had a guy go over it and he just replaced the rectifier and now it's fine so thanks again
cheers
mick
cheers
mick
