Jupiter 100H 06.06.18 08:48 |
Registriert - Registered: 13 Jahre - Years Einträge - Posts: 121 |
Hello everybody
I'm working on a Jupiter 100H
The grippermotor does not stop
It takes a record and returns it without playing
Cancel-switch is working
Safety switch is working
Microswitch is working (tonearm)
Play-relay is working
Mute relay is working
Who can help me with this?
Re: Jupiter 100H 10.06.18 18:38 |
Hello Timroy,
Did you check these troubleshootings?
Re: Jupiter 100H 11.06.18 03:15 |
Re: Jupiter 100H 12.06.18 14:37 |
From your description and answers it's difficult (for me) to understand what steps in detail you did already.
Maybe you can describe a little bit more. I understand:
- All switches and relays were measured for being ok.
- All contacts and mechanical parts were cleaned, e.g. the cams can move freely and as far as they have to.
- All mechanical adjustments were checked.
- The circuits were followed, compared with schematics and checked.
I checked in a later manual. It gives these hints as well:
Cam switch C4 not closing.
Amplifier relay not operating.
Amplifier plug loose in power supply.
If still no success, in that case I hope another user can help better - and/or you follow again all circuits and adjustments given in a service manual.
Kind regards - Hildegard Stamann
Re: Jupiter 100H 13.06.18 03:17 |
Cam switch C4 is closing.
Amplifier relay is operating.
Amplifier plug not loose in power supply
