rock ola regis 120 29.01.18 10:38 |
Registriert - Registered: 6 Jahre - Years Einträge - Posts: 3 |
HI,
MY ROCKOLA REGIS TURNTABLE IS RUNNING FAST
I WAS ADVISED TO CHANGE THE IDLER WHEEL LAST YEAR AND THIS CORRECTED THE PROBLEM ,BUT IT HAS NOW RETURNED .
ANY ADVICE WOULD BE APPRECIATED
JIM
JIM
Re: rock ola regis 120 30.01.18 05:53 |
Registriert - Registered: 13 Jahre - Years Einträge - Posts: 121 |
Does the jukebox run on 50 or 60hz ?
Re: rock ola regis 120 30.01.18 09:05 |
Registriert - Registered: 7 Jahre - Years Einträge - Posts: 27 |
Hello,
if you run on 50 Hz, your conversion spring is present?
Maybe some oil on idler wheel/ turntable: clean up with soap and water.
Kind regards,
Frank
Kind regards,
Frank
Re: rock ola regis 120 30.01.18 10:12 |
Hello Jim
The idler wheel can not cause the turntable to run too fast. If it is hardened or oiled, it can slip and the turntable runs too slow. If it runs too fast, there are two possibilities. The box could be converted for 50 Hz operation, but operated at 60 Hz. In this case, remove the spring from the motor shaft. Or it could be a wrong (too thick) spring mounted.
Best regards - charly49
Re: rock ola regis 120 30.01.18 16:06 |
Re: rock ola regis 120 01.02.18 16:31 |
HI,
THE SPRING IS IN PLACE ALL THE MOTOR MOUNTS LOOK SOUND
AS ITS IN THE U K ITS FUNNING AT 50 HZ MAINS
WHAT IS RHE LARGEST PERMITTED DIAMETER OF THE SPRING ?
jim
jim
Re: rock ola regis 120 02.02.18 13:37 |
Hello Jim
I remember that years ago we had exactly the same problem with a Tempo2. I picked out the old post: [www.jbw-forum.de] . Maybe in your turntable is also incorporated such a ring. Incidentally, I still do not know why the ring was made for Tempo2. The diameter of the motor shaft with spring must be exactly 5.1 millimeters.
