Rowe AMI R-84 and R-87 power supplies 110v to 240??
geschrieben von - posted by Blunder
26.09.17 15:25
Hi all
Just wanting to know if you can internally reconfigure the 110v power supplies/different tappings to use 240v or do I need to run a seperate 240v stepdown transformer to 110v??
Thanks in advance
1 mal bearbeitet. Zuletzt am 26.09.17 15:26.
Re: Rowe AMI R-84 and R-87 power supplies 110v to 240??
26.09.17 16:51
Can you tell us the number from the power supplie ?
29.09.17 15:52
If the Rowe ami power supply was supplied as a European export the supply voltage would have been 110/115 volts.
The supply voltage is usually clearly marked on the power supplies, if it is indeed a 110/115 supply then the easy option is to fit a 240 to 110 step down transfer into the jukebox.
Regards
Alan
Alan Hood
ami-man
UK
