Wurlitzer Centennial 2000
geschrieben von - posted by seancalla
05.02.13 15:35
Hi
This jukebox was working fine until lately. Now when a record is selected it will select ok but will not reject at the end of the record, (i am more familiar with rockolas's and wurlitzers from the 70's and 80's), i presume the reject is controlled by a blade switch or microswitch. Has anyone any advise on this on what might be causing this problem
regards
seancalla
Re: Wurlitzer Centennial 2000
05.02.13 15:52
Hello!
On the backside of the Tonarm under the silver Cover is a Microswitch and this Switch must be
the Problem. Can you switch off by the Cancelswitch on the Amplyfier?
mfg Willi!
05.02.13 16:10
Hi
Thanks for the quick reply,The switch on the amplifier doesn't work either but i will check out the tonearm
regards
seancalla
