NSM CITY l
geschrieben von - posted by seancalla
NSM CITY l
08.11.12 22:27
Hi
Would cause a previously working NSM city l to stop picking up records for playing, the carriage will move back and forth but will not pick up a record
regards
seancalla
Re: NSM CITY l
09.11.12 20:15
Hey Sean,
does the display count the steps while the carriage is moving ? Does it only move once per dialed record ?
Cheers
Kai
Re: NSM CITY l
09.11.12 20:58
Hi
It counts the steps while the carriage is moving, it moves a couple of times per dialed record, is this something to do with the LR relay and trip solenoid
regards
seancalla
Re: NSM CITY l
09.11.12 21:11
It looks like the solenoid isn't released. Do the numbers in the display make sense ?
When the carriage is passing the position, is the number right ( you can halt the carriage, but be very carefully!
When teh carriage passes the correct position, ist the relais active ?
Re: NSM CITY l
13.11.12 20:47
Hi
My mistake it does not counts the steps while the carriage is moving, the number 68 is displayed in the display, it keeps moving back and forth, if i manually activate relay Lr the carriage will stop and take a record
regards
seancalla
Re: NSM CITY l
14.11.12 00:07
Hey sean, then you have to check if the Opto-Couplers are still fine..it may have catched some dust, there's a dozen possibillities which may cause this to happen.
You may also check the end-switch on the right, whether it still opens and closes correctly.
Re: NSM CITY l
14.11.12 01:26
thanks, will check these out
