Seeburg M100a 45 or 78 RPM??
geschrieben von - posted by jaro
09.09.05 08:43
Hi,
Is there a possibility to see if a M100a is a 45 RPM machine or 78 RPM machine?
I know they have different gears, but can I see it direct with what kind of machine I dealing with
or must I wait till I get the machine up and running.
Who is able to answer?
Many thanks
Jan --- Seeburg.dse.nl ---
Re: Seeburg M100a 45 or 78 RPM??
12.09.05 15:48
Hello Jan,
there are a few changes which needed to be made to convert the M100A to play 45s instead of 78s.
The easiest to check is to try to put a 78 record in the magazin. If that is possible it might be still on 78.
If converted to 45s there should be metal bars on both sides of the magazin to "lift" the 7" records up.
Kind regards - Hildegard Stamann
