Jukebox wallbox-Playmate Rusric
02.09.10 15:38
Hi
I have a wallbox, with the name playmate rustic. When connected up the 12 volt dc fuse keeps blowing. There are three leds one for 5vdc, one for 12vdc and one for 24vac. The 12 volt one keeps blowing but the other two are fine, nothing obvious on the board. Beside each fuse is a bridge rectifier, i suspect this may be the problem. There is nothing on the component except the following
BR32 87, does anyone know a suitable replacement rectifier or what the specification on it.
regards
Sean
Re: Jukebox wallbox-Playmate Rusric
02.09.10 19:20
Hi!
Can you send a picture about this Part than is it easy to find out a replacement.I could not find this partnumber anywhere.
Best regardsWilli
03.09.10 00:37
Hi
Will do
regards
Sean
03.09.10 08:47
BR32 is a standard 200V 3A bridge rectifier. [www.datasheetcatalog.com]
03.09.10 16:53
Hello Sean,
Which Playmate Rusic wallbox version do you have?
I have parts from the early version up to the Mark 4 version.
These wallboxes were made by Hazel Grove Music of Manchester, they were made to work with several types of jukebox.
Some of HGM wallboxes had boards in that were produced by MHG (Music Hire Group Leeds).
Please contact me if you need parts or advice.
Regards
Alan Hood
ami-man
UK
alan-hood@datex.co.uk
04.09.10 00:29
Hi
The main board inside it is a HGM issue 2, the parts i need are the main board and the transformer, have you got these and what would be the cost
regards
Sean
04.09.10 00:41
Thanks for the information
regards
Sean
