NSM Prestige 160 26.12.21 18:09 |
Registriert - Registered: 3 Jahre - Years Einträge - Posts: 4 |
My NSM 160 prestige doesn't recognize when it is at the end of a record. It doesn't cut off. According to the manual it has something todo with the magnetic reed switch. However I can't figure out how to solve it.
Does anybody have an idea?
You can reply in german. I can read and speak it but can't write it very well.
Danke
Vincent
1 mal bearbeitet. Zuletzt am 26.12.21 19:09.
Danke
Vincent
Re: NSM Prestige 160 26.12.21 22:26 |
Registriert - Registered: 5 Jahre - Years Einträge - Posts: 77 |
hi vincent ,
The reed switch is the gray thingy with the screw right in front of the tone arm , when u unscrew it a little u can move the reed switch forward en backwoods just so u have the sweet spot u need that the switch reacts .
If that does not work maybe the reed switch is defect or the wire is disconnected .
i will try tot find a photo for you with the switch when i can .
regards ...........nico
1 mal bearbeitet. Zuletzt am 26.12.21 23:01.
Re: NSM Prestige 160 29.12.21 17:41 |
Hello Nico,
Tnx for your quick response.
I moved the reed switch but it doesn't seem to make any difference.
Maybe I'm wrong that this is the problem.
I've tried to reset the jukebox but it doesn't react to anything. The transfer arm stays in upright position.
Maybe it's time to let someone with more knowledge look at the problem.
Now I need to find somebody in the Netherlands (Limburg) who can fix this.
Tips? You?
Kind regards,
Vincent
1 mal bearbeitet. Zuletzt am 29.12.21 17:42.
Tips? You?
Kind regards,
Vincent
Re: NSM Prestige 160 29.12.21 22:34 |
