NSM esllA consulette wallbox
geschrieben von - posted by seancalla
31.10.21 16:39
Hi
Has anyone come across common faults with this wallbox. The power supply board in the wallbox is not turning on. I have 25volts ac going into wallbox but not getting any voltages at the transformer. The fuse in the wallbox are all good. There are 4 fuses on the power supply. Once this isn't working the keyboard or credit unit won't work. Hideaway is fine with control board working. Just a general question if anyone had seen this before
Seancalla
1 mal bearbeitet. Zuletzt am 31.10.21 16:42.
Re: NSM esllA consulette wallbox
08.11.21 12:50
Hi
Would anyone have spare parts for this wallbox
Seancalla
08.11.21 12:58
Hello Seancalla,
please use the classified online market to search for parts.
You get the best response if you show a good and detailed picture of what you need.
Without there are often no replies.
Kind regards - Oliver Stamann
14.11.21 00:04
Hi
Just for anyone that comes across this problem, the solder joint on the live input to the power supply board was dry so not making full connection. All good now
seancalla
