rockola 430 select question
geschrieben von - posted by bopper
17.04.19 10:56
Hi All again
i have a question about the 430 i recently rebuilt with your help, the box is playing fine but now and then after a selection is played instead of returning to the home position it selelects the same record and plays it again then it goes to home postion ok ,any advice or info would be great ,thanks
mick
Hallo alle wieder
Ich habe eine Frage zu dem 430, den ich kürzlich mit Ihrer Hilfe neu aufgebaut habe. Die Box spielt gut, aber ab und zu, nachdem eine Auswahl wiedergegeben wird, anstatt zur Ausgangsposition zurückzukehren, wählt sie dieselbe Platte aus und spielt sie erneut ab. Danach geht es zur Ausgangsposition ok, ein Rat oder eine Info wäre toll, danke
mick
Re: rockola 430 select question
17.04.19 15:42
Hi Mick,
it is difficult with now and then failures. The selector levers will not be resetted. Here is the description of the proper operation.
Best regards
Andre
17.04.19 21:32
Hi Andre
thanks for the info,i know these silly things occur now and then as they do with my other 430, so could the select lever (s) be sticking or the A + B levers on the read-out solenoids i will check for free movement
regards
mick
18.04.19 19:03
Hi Mick,
how often does it occur? Is it always another selection? A or B side?
I would check the carriage hammer and their position in relation to the selector levers.
Best regards
Andre
19.04.19 21:57
Hi Andre
i will make a few selections and check how often it plays a selection twice and if it's A or B side, i will post after testing
cheers
mick
31.05.19 08:32
Andre
after being tied up with other things i have managed to get back to the problem with the selection, i cleaned all the levers on the selector assembly( slight spray with cleaner fluid) and checked the levers on the carriage for easy movement seemed ok, then tried a few selection and it seems to have worked the basket returns to home position after selections end ,so hopefully all ok ,thanks again
regards
mick
