NSM Prestige 2 Jukebox - Normal operation ?
geschrieben von - posted by Jukebox Bobby
29.03.18 11:40
Hello everyone, just joined
For years I've been after an NSM Prestige 2 Jukebox and finally purchased one a few weeks ago. I love it... it's great !! and visitors to the house are so impressed.
I work here in the UK as a Police officer, however i originally trained as tv engineer in the 1980's before joining the force, so have some technical background ( a bit rusty now ). Part of the enjoyment of buying the jukebox is keeping it going... hopefully solving any faults myself.
Since buying my NSM I have replaced some of the bulbs, fitted new base drivers ( although I was disappointed sad smiley not to find the originals second hand somewhere they are 6.5 ohm 9.5 inch..) Also lubricated the motor was a bit stiff and replaced the electrolytics in the amp power/ supply section.
Can I just ask if anyone can advise on the following..
The jukebox seems to be working ok, although Iv'e noticed the carriage sometimes clicks and "hesitates" for a split second whilst it is returning along the rail back to the start position, not all time. Does anyone know if this is normal ( is it just braking ? ) or a sign a fault is developing ? It selects records and plays ok
Also.. there is a minor mains hum through the speakers whilst no record is selected, I though replacing the Caps would have solved it but still there. Again is it normal
Many thanks
Rob
Re: NSM Prestige 2 Jukebox - Normal operation ?
19.04.18 20:05
Hello Rob,
I can't answer the first question, though I doubt it is a normal operation that the carriage runs hesitant once in a while. Did you check if this could be a mechanical problem - stiff cable ?
Regarding the hum: Are you sure it comes through the speakers? Sometimes ballasts cause a hum which can be heard in standby already. To check take out the fluorescent lamp. If no hum can be heard now the problem is the ballast.
Kind regards - Hildegard Stamann
19.04.18 23:24
Da mein Technisches Englisch noch schlechter ist als das bisschen Englisch was is so drauf habe Versuch ich erst garnicht auf Englisch zu Antworten .
Ich denke das Klacken ist normal . Vermutlich kommt das Klack Geräusch von der Rutschkupplung wenn der Laufwagen in den Anschlag läuft und der Antriebsmotor noch nachläuft . Dann überspringt diese und das erzeugt ein Klack Geräusch .
Das Thema Summen , Brummen und ähnliche Nebengeräusche im Stillstand sind mitlerweile sowas wie eine Unendliche Geschichte bei den ES und ES II Zentralen . Die Dinger sind so kompliziert gebaut das man manchmal garnicht Glauben mag woher die Geräusche kommen . Es gibt die Möglichkeit das ein Surren durch einen schlechten Betriebsartenschalter im Laufwerk kommt . Es kommt zu wechselnden Quitschgeräuschen wenn im Display die Anzeige die Top 10 durchschaltet bzw. die Anzeige wieviele Kredite es für die einzelne Münzen gibt . Hier wird der Fehler vom Computer verursacht . Das selbe entsteht auch wenn die Abschirmleitung um das Displaykabel nicht geerdet ist . Von defekten Bauteilen will ich garnicht erst Anfangen .
21.05.18 14:01
Hi Rob, I dont know if you fixed your hum, but I had a similar problem, In my case it was the K select button it would not return fully after being selected for playing a record, or even if it was just slightly touched. I would wait till I ran out of credit and just press it firmly and it would return to its proper position hum gone.
