AMi Pulse Converter Overhaul - Anyone? 10.08.16 19:07 |
Registriert - Registered: 8 Jahre - Years Einträge - Posts: 37 |
Hello,
Anyone had any experience with this overhaul? Looks like a brilliant idea. I am thinking about trying it. Please check the link
[www.yourjukebox.co.uk]
Cheers
Cheers
Re: AMi Pulse Converter Overhaul - Anyone? 10.08.16 19:22 |
The pulse Converter is not so difficult to Oberhaul .
And i Like it Original .
Eric
Eric
Re: AMi Pulse Converter Overhaul - Anyone? 10.08.16 19:53 |
Das sieht aus wie eine Weiterentwicklung von Quadrelli aus Italien .
Re: AMi Pulse Converter Overhaul - Anyone? 10.08.16 20:42 |
Hello paulmolive
We had more than two hundred AMI H and I to service in the good old days. It was since then until now one single defective relay, which had to be rewound. The only error which occurred relatively frequently, was a burned out contact rivet on the Pulse Relay. The solution with the new relay on a PCB could be useful when a blacksmith worked on the pulse converter and has it so badly damaged that a normal repair is no longer possible. It is usually sufficient to clean and adjust the contacts. So also the collection value of the Jukebox is retained, which would not be the case with a conversion.
Best regards - charly49
