Hi
I have noticed my Rockola 1454 has a loose wire just dangling from the cam limit switch, the wire has a washer attached which I would presume requires earthing having some real issues at the moment detailed below
I have another issue with my rockola 1454, the carousel, it rotates back and forward even if selection is not made, it happened a few weeks ago but I was told to check the pin bank which i did, the issue appeard to be a pin was stuck
all has been well since but today it happened again, so i have gone round the pin bank meticulously and moved all the pins and checked for any sticking or out of place pins, to no avail
could the issue be anything else
it still selects no problem and plays but when the selections have all been played the carousel does not park
any suggestions would be greatly appreciated.
Noise and carousel issues
I have checked all the microswitches for movement and now checked the control box, I removed the box completely and cleaned all the contacts, sprayed with electrical cleaner
I still had the same issue so decided to move the contacts manually whilst the power was still connected to the jukebox.
I must have shorted something as the power to the box tripped, it did spark and I had blown a fuse
but now the control box does not work as it should, the gripper motor does not stop and I have had to remove also the the carousel control switch is not working correctly infact the jukebox is unusable with buzzing and overheating of the selector
the cancel relay is not working I suspect i have blown a number of capacitors or restors within the box, and my require a rebuild
any suggestions would really help.
