Hello expert.
I have restored the Wurlitzer 2200, 1958.Problem: When I select on the letter, then number button, the toothed alu-carousel (68245) plate will rotate 1-2 second and then turns off. But when I press the two buttons at the same time 1-2 second, the Sellector Crank (110943) starts to rotate and at the same time the Latch Solenoid (112104- in the selector switch plate) chatter 4-5 times but always find the right record and operates the complete cycle.
l have changed all the letters and numbers solenoids (30 pcs), letters and numbers switches and many others relays and components. Also I restored the entire cabin and all the chrome parts. Now the juke is like new, but... This same fault was before I bought this juke. This chatters is not part of the operation. I have a Service Manual and wiring diagram - model 2200.
How can I fix this failure?
I am very grateful, if somebody can help me with this problem. Also I can give to you know how, what I have.
Best regards, Jukeke
