NSM Satellite 200 25.06.14 14:40 |
Registriert - Registered: 14 Jahre - Years Einträge - Posts: 275 |
Hi
I have one of these jukeboxes which has the following problem, carriage does not stop in home position at right side of of record basket, from other nsm's i have had this would be the home position when machine is switched on or after the last record is played. The machine is not showing any error codes. It accepts a selection and the display shows the various records slot numbers as it scans, the carriage will stop at the corrrect point, pick up the record, but after the tone arm lands on the record the record is rejected. After that the carriage weill scan back to record slot 287 and move left to about slot 237 and stop and not record slot 299 on the far right. Has anyone any ideas about this
regards
seancalla
1 mal bearbeitet. Zuletzt am 25.06.14 14:50.
regards
seancalla
Re: NSM Satellite 200 26.06.14 15:34 |
Hi Just an update on the above in case someone else comes across it, a connection between the 22R resistor in the centre of the control board was broken, fixing it back together allowed the record to be played, as for the homing position maybe the nsm satellite does not home on the far right, as there is no issue with the carriage stopping at the various selections
regards
seancalla
regards
seancalla
Re: NSM Satellite 200 27.06.14 00:54 |
Registriert - Registered: 19 Jahre - Years Einträge - Posts: 4.239 |
Die Satellite 200 hat ES III Technik diese Arbeitet nicht mit Endkontakt sondern mit Lichtschranke am Laufwerk . Der Synchronpunkt und Endpunkt ist daher der Bereich wo die Lichtschranke von Hell auf Dunkel Tastet . Schau mal unter das Plattenmagazin da siehst du diese Markierung . Sie befindet sich etwa 10 cm rechts vom Anschlag .
Re: NSM Satellite 200 27.06.14 16:37 |
Thanks for the help
