Jukebox NSM Hit 120B problem 20.02.13 13:30 |
Registriert - Registered: 11 Jahre - Years Einträge - Posts: 3 |
Hi all,
I have bought some time ago Jukebox NSM Hit 120 B (Serial no 61526679, year 1974-1978) and I need some technical help and advices to repair it.
Problem is that the arm which will raise the record up has stacked in upper position and won't go back to original position to be able to play the record.
I appreciate if I can get some help and advices from you.
Kind regard,
Kimmo Hirsimäki
Kokkotie 4
54850 Kuukanniemi
Finland
Kind regard,
Kimmo Hirsimäki
Kokkotie 4
54850 Kuukanniemi
Finland
Re: Jukebox NSM Hit 120B problem 20.02.13 16:56 |
Hello Kimi,
is it possible that the carriage is in Play modus?
That means does the motor run?
Regards P.
Regards P.
Re: Jukebox NSM Hit 120B problem 21.02.13 10:07 |
Hello P.
yes the motor runs like playing record.
Any hints what to do?
Best Regards,
Kimmo
Best Regards,
Kimmo
Re: Jukebox NSM Hit 120B problem 21.02.13 12:09 |
Hello Kimmo,
ok., in this case push the tone arm to the end of record position, this shall stop the play modus, tilts the record lifting arm down and moves the carriage to the park position.
Regards P.
3 mal bearbeitet. Zuletzt am 22.02.13 13:16.
Regards P.
Re: Jukebox NSM Hit 120B problem 21.02.13 14:43 |
Re: Jukebox NSM Hit 120B problem 02.03.13 09:47 |
